DVD Arcnitect - Blu-ray issue
COW Forums : VEGAS Pro
Rick Hughes
on Oct 23, 2015 at 12:56:42 pm
I have Movie Studio Platinum 12 and DVD Architect 5.0
Both working fine for DVD
Now starting out on Blu-ray projcets .....
Under help for DVD architect it states that I can create Blu-ray discs ... and simply I can go to 'file > make Blu-ray disc'
However when I go to file .. it does not give a Blu-ray disc option ? only DVD
The wording everywhere says DVD ... no mention of Blu-ray ....... is there an upgrade or something I need. ?
In the icons at top of screen .. only 'make DVD' again nothing for 'make Blu-ray'
I have tried 'get update' and it tells me I am on latest version.
Is there a config or patch required ?
Jorma Nippala
Re: DVD Arcnitect - Blu-ray issue
on Oct 23, 2015 at 1:38:49 pm
[Rick Hughes] "I have Movie Studio Platinum 12 and DVD Architect 5.0
Is there a config or patch required ?"
No. Create a Blu-ray project from File > New and choose Blu-ray Disc format.
Rick Hughes
Re: DVD Architect - Blu-ray issue
on Oct 23, 2015 at 2:36:35 pm
I was looking in help file it shows:
and following those instructions ... under file:
No option for Blu-ray there, hence my Q. is there something wrong with my version.
I did try your steps of File new > Single movie > Bluray that does work .... but still concerning about the points above.
Jorma Nippala
on Oct 23, 2015 at 3:01:09 pm
[Rick Hughes] "I did try your steps of File new > Single movie > Bluray that does work .... but still concerning about the points above."
Do you mean you don't see "Make Blu-ray Disc" on the Toolbar and under File after you tried the steps?
Rick Hughes
on Oct 23, 2015 at 3:26:24 pm
I see only make DVD ... screen grab was in previous post
Jorma Nippala
on Oct 23, 2015 at 3:57:19 pm
Yes I did notice your previous screengrab.
This is what you should see after you followed the steps.
My screengrab is from DVD AS 5 build 157 (not the latest). Possibly a buggy build or a faulty install, if you don't get the BD option and a user error is ruled out.
John Rofrano
on Oct 23, 2015 at 11:08:16 pm
You will not see the Make Bu-ray Disc option in a DVD project. You must first create a Blu-ray project, or change your DVD project to a Blu-ray project. That is the only way to get the Make Blu-ray Disc option because it only appears in Blu-ray projects.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Rick Hughes
on Oct 23, 2015 at 11:10:52 pm
Thanks for the explanation.
John Laird
on Oct 24, 2015 at 2:09:44 am
You can also go to the Tools menu in Vegas and create a Blue-ray disk right from Vegas. The caveat here is It won't have a menu, but it will play as soon as you put it in the Blue-Ray Player.
John
Rick Hughes
on Oct 24, 2015 at 8:41:29 am
...in this case I need to put menus in place.
