Text Media Generator window layout changed to horizontal instead of vertical in Sony Vegas Pro
COW Forums : VEGAS Pro
Chris Fox
on Oct 20, 2015 at 4:14:15 am
I am using SVP 13
Here is a screenshot of the issue I am observing.
http://i.imgur.com/UGi5Ek8.jpg
My text media generator window has changed its default layout to horizontal. Double-clicking the edge of the window only expands it to fit the horizontal layout.
I would like to use the default vertical layout as seen in this picture:
http://www.computershopper.com/var/ezwebin_site/storage/images/media/images...
Jorma Nippala
Re: Text Media Generator window layout changed to horizontal instead of vertical in Sony Vegas Pro
on Oct 20, 2015 at 7:51:38 am
Your own screenshots show what is different. See the upper right corner of the FX window and hover your mouse over the three column options. Click the option you want to use.
Chris Fox
on Oct 20, 2015 at 6:05:04 pm
Ah, thank you. I must have clicked that button when moving the window. I noticed the same issue in several other plugin windows. Searching for window layout gives me all sorts of answers but the correct one which is yours.
Thank you again.
