Correct settings for Blu-ray(Europe)
COW Forums : VEGAS Pro
Rick Hughes
on Oct 19, 2015 at 3:37:42 pm
I have been editing up a number of projects ... not committed any to Blu-ray disk yet.
What is the correct or most optimum render settings for Blu-ray.( For Europe & Oz)
At front end the projects settings options give:
1920 x 1080 with frame rate of 23.976 (IVTC film) 25 (PAL) or 50 (Double PAL)
The render options are 1920 x 1080 24p 1920 x 1080 50i or 1920 x 1080 60i
My sources are not interlaced. I am sort of convinced that for modern Blu-ray players & 1080p TV's then I should stick with 1920 x 1080 24p, until searching here I found this comment:
"Yes, PAL countries should use 1080-50i and NTSC countries should use 1080-60i."
I also tried Sony web site and it states:-
"In the Vegas or Movie Studio "Render As" window, select MainConcept MPEG 2 as your format. Then select Blu-ray 1920x1080-60i, 25 Mbps video stream template (select 50i if you are in Europe)."
Why use interlaced ? ... if playback is on a full HD system (1080p) why ?
Probably my lack of understanding, would like to understand.
John Rofrano
Re: Correct settings for Blu-ray(Europe)
on Oct 19, 2015 at 8:38:18 pm
[Rick Hughes] "Why use interlaced ? ... if playback is on a full HD system (1080p) why ?"
Because Blu-ray is an interlaced format for backward compatibility and if you want to deliver PAL Blu-ray you should use 1080-50i. This will not make a bit of difference in the quality of your image because both fields will be from the same progressive source frame. It's just how Blu-ray is.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Rick Hughes
on Oct 19, 2015 at 9:53:25 pm
Thanks ... that's what I'll use then.
Rick Hughes
on Nov 16, 2015 at 6:14:40 pm
John .. been following this advice ... and used the MainConcept 1920x1080, 50i template ... but maybe I did not use it correctly.
If I try to render this with frame rate at default (50) it fails with 'an error occurred while creating the media file'
If I set it to 25fps it Renders OK.
I also tried 50fps and set it to progressive - fails with same error message.
What should I be using here? Goal is a Blu-ray compliant 1920x1080 ... and assumed for best HD this should be 1080p.
John Rofrano
on Nov 18, 2015 at 12:55:54 pm
[Rick Hughes] "John .. been following this advice ... and used the MainConcept 1920x1080, 50i template ... but maybe I did not use it correctly."
That's right. You set the frame rate to 50 and Blu-ray only supports 25 fps. You need to use the Blu-ray templates without changing anything except maybe the bit rate if you want them to remain compliant with the spec.
~jr
