Hard to explain, weird problem
COW Forums : VEGAS Pro
Devin Eddd
on Oct 19, 2015 at 4:32:26 am
So I'm making a montage parody for a friend, and while I was doing this; I saw that the picture was like vanishing when moved down
Here's what I mean
Skip to the first 16 seconds
What I'm trying to say is, how can I move it down, without is vanishing
John Rofrano
Re: Hard to explain, weird problem
on Oct 19, 2015 at 12:11:20 pm
The problem is that your aspect ratio is wrong for the event you are editing. When you open Pan/Crop, right-click in the window and select Match Output Aspect and your image will stop disappearing.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Devin Eddd
on Oct 19, 2015 at 7:27:51 pm
Tried this, image is still vanishing
John Rofrano
on Oct 19, 2015 at 8:34:37 pm
Try righ-click Restore then right-click Match Output Aspect. This will start you off fresh.
Otherwise use Track Motion to place the image in the correct position.
~jr
