Problem with Pitch Shifting
COW Forums : VEGAS Pro
Eric Floyd
on Oct 18, 2015 at 11:33:56 pm
I've just recently moved from Vegas 11 to Vegas 13, and I've noticed that the + and - keys don't seem to change the pitch as they did in Vegas 11. I enabled this setting with "ctrl-shift-i", but it still doesn't seem to work. Anyone know how to fix this?
John Rofrano
Re: Problem with Pitch Shifting
on Oct 19, 2015 at 12:09:07 pm
Works for me. I just dropped a video on the timeline in Vegas Pro 13.0, selected the audio and pressed the equal key (=/+) a few times and got the +1, +2, +3 indicator that the pitch was shifting. It says +/- but to actually type a plus you need to use the Shift key but to shift the pitch you press the plus key without using Shift which is really the equal key at that point. (same key just without shift). but if you use this in Vegas Pro 11 I'm sure you already knew this.
Not sure why it's not working for you.
~jr
http://www.johnrofrano.com
http://www.vasst.com
