Imported Video Interlaced
COW Forums : VEGAS Pro
jasper klatten
on Oct 3, 2015 at 5:33:31 am
If I watch the source file in VLC it looks perfect.
If I import the file to Vegas it's horizontal lines of death.
I set the project properties to source file (PAL25) and deinterlacing to blend or interpolate fields. Nothing works, in preview it looks bad and after rendering it's the same.
Please help me, you would save my night!!
edit: i dont know if interlacing is causing the problem. notice that the above picture is a photo, so it is not moving!!
Graham Bernard
Re: Imported Video Interlaced
on Oct 3, 2015 at 8:28:25 am
Right click on still and select Deinterlace.
G
jasper klatten
on Oct 3, 2015 at 12:33:49 pm
It is a video! But there is shown a photo in the video and its all blurry. So I dont know if it's deinterlacing (i'm a noob) but right clicking and selecting deinterlace didnt do nothing for me. Any other ideas? Thank you!
John Rofrano
on Oct 3, 2015 at 6:22:32 pm
[jasper klatten] "If I watch the source file in VLC it looks perfect."
That's because VLC includes a deinterlacer so it handles the interlacing properly like a TV does.
[jasper klatten] "If I import the file to Vegas it's horizontal lines of death."
Actually, there is no death associated with it. It sounds like you are just "deadly" afraid of what you don't understand. ;-) Interlacing is required for correct playback on televisions and is very easy to remove if you don't require it.
[jasper klatten] "I set the project properties to source file (PAL25) and deinterlacing to blend or interpolate fields. Nothing works, in preview it looks bad and after rendering it's the same."
That's because you probably didn't turn on the deinterlace filter for the preview window.
Try this:
  • Right-Click on the Preview window and select Preview Device Preference...
  • Check the option [x] Apply deinterlace filter
  • Press OK
Your preview windows will now deinterlace the video just like VLC does. BTW, This has absolutely not effect on what the final video will look like. It's just a preview setting. In order to remove the interlacing from your rendered video you must render with a progressive template.
~jr
http://www.johnrofrano.com
http://www.vasst.com
