Multicam Nite Mar !!!!!
COW Forums : VEGAS Pro
Welland Man
on Oct 2, 2015 at 9:48:26 pm
bit complex on this one so here goes
did a band 2 camera none of the clips actually match so used sony color correcter for brightness and looking the same (ish) !!!
right ok when i go into the multi cam i lose all the settings i made and reverts back to very dark on one camera
Mike Kujbida
Re: Multicam Nite Mar !!!!!
on Oct 2, 2015 at 10:21:43 pm
You need to apply the effects to the events (what Vegas calls a clip) while it's in the project media tab. As you already found out, you lose everything you apply on the timeline.
John Rofrano
on Oct 2, 2015 at 10:40:21 pm
As Mike was pointing out, any color correction needs to be applied to the Media while it's in the Project Media bins. Media FX will not be affected by multi-cam. Do not attempt to add any FX to individual Tracks or Events until you build the master multi-cam track. Then you can treat that Track like any other.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Graham Bernard
on Oct 3, 2015 at 3:42:44 am
If you CAN'T get too close with the corrections, then consider blowing the worst Events using a completely different tack/approach like Black and White or overly colour -rich and use this "cutaway" as a more narrative-rich option. I've done this and it works.
Grazie
Nigel O'Neill
on Oct 4, 2015 at 12:17:54 pm
[John Rofrano] "As Mike was pointing out, any color correction needs to be applied to the Media while it's in the Project Media bins. Media FX will not be affected by multi-cam. Do not attempt to add any FX to individual Tracks or Events until you build the master multi-cam track"
Hmmm...that's interesting. I have been adding event level FX for color correction/grading since Vegas 9, but my multicam editing has always been with your Ultimate S plugin. It lets me do it this way. Have I been doing it wrong all these years :-) ??
My system specs: Intel i7 970, GTX570, 12GB RAM, ASUS P6T, Vegas Pro 12 (x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
John Rofrano
on Oct 4, 2015 at 8:39:08 pm
[Nigel O'Neill] "I have been adding event level FX for color correction/grading since Vegas 9, but my multicam editing has always been with your Ultimate S plugin. It lets me do it this way. Have I been doing it wrong all these years :-) ??"
LOL! No, Ultimate S Pro doesn't have the restrictions that Sony's built-in multicam implementation does. That's why people still use Ultimate S Pro and infinitiCAM.
Ultimate S Pro copies the events onto the master timeline. This is why the FX stay with the events when they are copied. Sony multi-cam combines the media from the events into a NEW event as Takes. That's why Event FX get left behind and only Media FX work in the Sony implementation.
~jr
Welland Man
on Oct 3, 2015 at 3:25:23 pm
is there a youtube tut on this as now quite understanding
John Rofrano
on Oct 3, 2015 at 7:08:51 pm
[Welland Man] "is there a youtube tut on this as now quite understanding"
What you need to understand is that you can apply FX at 4 different levels in Vegas Pro:
  • Event FX
  • Track FX
  • Media FX <-- You want this!
  • Bus FX
All you need to do is right-click on the event that you want to color correct and from the pop-up menu select Media FX and then apply the Color Corrector that way. Get the video looking the way you want and then use the multi-cam function. You can even do that now to the multi-cam events you have already created.
~jr
Welland Man
on Oct 4, 2015 at 2:21:37 am
wow cracked it i think :)
Aaron Star
on Oct 4, 2015 at 2:45:52 pm
For shorter subjects, I just use multiple tracks for each camera angle, and group the takes. Then using a blank top track for selection, hitting S for spilt, selecting the top down events you do not want to see and muting them. I find this works more fail safe than then popping in an out of the multicam view. Plus it keeps all your options open as far as applying FX. The blank top track for selection cuts all tracks below vs just the clip on the cursor.
I find the Multicam useful for long event type coverage type or TV program type editing. Also if you perform CC on your camera angles before, and then just use Multicam just for cutting.
Maybe changing the order of the way you do things might help too. Apply FX after the cutting is done. Then expand the tracks out of Multicam, which gives you basically the muted track view described above.
