How to change color of the same frame over time?
COW Forums : VEGAS Pro
Julia Abelle
on Oct 1, 2015 at 8:26:46 pm
Hoy!
Really having hard time to describe and therefore find relevant tutorial. I saw many times vids where the color of the clip would be changing as it goes... for simplicity say from color to black/white.
It's really cool master but how to do this effect?
Graham Bernard
Re: How to change color of the same frame over time?
on Oct 1, 2015 at 8:57:51 pm
Apply a Desaturation FX and have it change over time.
Grazie
Julia Abelle
on Oct 1, 2015 at 9:03:41 pm
What about if color to color? If Want another color range to the end of the clip.
Graham Bernard
on Oct 1, 2015 at 9:07:21 pm
What is it you want to do?
Julia Abelle
on Oct 1, 2015 at 9:40:26 pm
A clip changing color over the course from start to the finish. Like here:
Is this a Desaturation effect in motion?
Graham Bernard
on Oct 2, 2015 at 3:39:12 am
Thank you for the sample, I now know completely appreciate what it is you wish to achieve.
Firstly that's a highly complex and subtle sequence, however. And secondly, that's something that VP can achieve.
Having only just watched it once I gave up counting beyond 20+ separate alterations. I would explore doing FXing to separate Events, plus Composiiting between Track layers.
If you are new to this work, then this project is an excellent way to learn loads! But make no mistake, this is complex and the skill, craft of that editor has been achieved from a long time in understanding the tools.
Grazie
Julia Abelle
on Oct 2, 2015 at 10:46:40 am
Fantastic answer, thanks loads! Once I have now learnt where to look, what operations to learn to achieve this it is half way through and will be all about finding the right tutorials by the name of effects.
Appreciate a lot!
Aaron Star
on Oct 2, 2015 at 3:38:31 am
Same thing. Learn how to key frame the Sony color corrector. Both examples are easy.
Julia Abelle
on Oct 2, 2015 at 10:47:49 am
Thanks you for your add!! Will check Key framing thing then :)
Russ Froze
on Oct 3, 2015 at 1:44:38 pm
hoy Julia, try this tutorial
Russ Froze
Julia Abelle
on Oct 3, 2015 at 8:42:11 pm
Oh, you make life easy for me :) Thanks a lot!
Russ Froze
on Oct 4, 2015 at 8:59:16 am
You are most welcome, I have made a new version with some important info or say quirks about keyframes in Vegas so If you watch again and think it's different then you are correct. If I left something out let me know and I will address it. Also I think I pronounced your name correctly this time. ;-) I think.
Russ Froze
Julia Abelle
on Oct 4, 2015 at 10:45:53 am
The new version has been replaced nicely and plays just fine. Can't thank you enough for your efforts! Very helpful :)
