Is there any way to PLAYBACK footage in Sony Vegas Pro 13 faster/slower?
COW Forums : VEGAS Pro
Alex Black
on Sep 29, 2015 at 12:05:17 am
I am wondering if there is any way to speed or slow the preview without affecting the clip itself (eg. No I do not want to use velocity envelopes or time-stretching). I just need the PREVIEW to be faster/slower because I need to cut down on editing time. Any advice?
Mike Kujbida
Re: Is there any way to PLAYBACK footage in Sony Vegas Pro 13 faster/slower?
on Sep 29, 2015 at 1:01:52 am
Use the J K L keys. J is reverse, K is pause and L is forward. Pressing the J or L keys more than once speeds up or slows down playback. 1, 2, 4 & 8 times as I recall.
Wayne Waag
on Sep 29, 2015 at 3:35:28 am
You can further adjust speed under Preferences|Editing|JKL/shuttle speed.
wwaag
Alex Black
on Sep 29, 2015 at 5:00:02 am
Exactly what I was looking for. And the chipmunk voice "side effect" of playing back speeded up footage is hilarious too. Thank you very much, Mike.
Aleksey Tarasov
on Sep 29, 2015 at 9:04:05 am
Another way - using the scrub control:
Vegasaur.com
David Eon
on Oct 29, 2015 at 1:39:48 pm
I use the small triangle node below the scrub control - drag it all the way to the right to set default playback at 4x speed, then use ENTER to playback at 4x and L to playback at 1x. You have to reset the node each time you restart Vegas though. Let me know if that helps.
DavidEon
