Crashing while rendering at 42%
COW Forums : VEGAS Pro
Mala Kas
on Sep 28, 2015 at 8:27:11 pm
Hey folks,
i am very confused about this.
I need to render out a video of 40 min of length.
But every time at 42% of progress it crashes.
At the beginning it sayd i need to update vegas to the newest version
but firstly i reset to standard values and tried again.
Same Problem, crash at 42%
Then i updated it to 13 Build 453
now it crashed at 42% with the following message:
Problem Description
Application Name: Vegas Pro
Application Version: Version 13.0 (Build 453) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\MSVCR90.dll
Fault Address: 0x000000006EFAE293
Fault Offset: 0x000000000001E293
Fault Process Details
Process Path: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
Process Version: Version 13.0 (Build 453) 64-bit
Process Description: Vegas Pro
Process Image Date: 2015-06-05 (Fri Jun 05) 14:53:04
can someone hlp me out here
thanks in advance
Mike Kujbida
Re: Crashing while rendering at 42%
on Sep 29, 2015 at 12:23:12 pm
Odds are that whatever media is at the 42% mark is giving you problems. Substitute a different piece of media and see if you still get the crash.
The other issue is the WinSxS fault module.
I googled it and found numerous references to it.
Here's what seems to be a good one.
How to address disk space issues that are caused by a large Windows compone....
Hopefully this will help you solve your problems.
