Timelapses and cropping
COW Forums : VEGAS Pro
Ryan Moyer
on Sep 15, 2015 at 10:52:06 pm
I've just started getting into timelapses. When I import my images (6000x4000) as a clip it automatically crops them to the video size (1920x1080). Is there a way I can have it leave them at their native resolution so I can crop myself and use that extra resolution to pan/zoom?
As an aside, I'm also having a problem with the sequence in the preview window being very grainy. These are high noise images (shot at ISO6400, night images) but the preview window is so massively grainy it's basically unusable, whereas when exporting everything looks fine and the grain is barely noticeable.
Norman Black
Re: Timelapses and cropping
on Sep 16, 2015 at 12:37:20 am
Vegas will use the full res of your photos when you pan/crop. By default Vegas does conform the source to the output dimensions but that is done after pan/crop in the pipeline chain. Therefore pan/crop sees the full source file dimensions.
I have done some slideshow stuff on 4000x3000 jpegs in a 1440x1080 project.
