I cannot move or resize a frame after using the mask option in Event Pan/Crop
COW Forums : VEGAS Pro
Valerio Alves
on Sep 7, 2015 at 9:26:38 pm
I'm using Vegas Pro 11.0. After using the option mask in Event Pan/crop I cannot see the guidelines with the big "F" to move the frame, no matter if I enable or disable the option mask again. The only way to see the guidelines again is using the option "undo", but this will not solve my problem since I first need to crop the frame berofe moving it. Does anybody knows how to solve this issue?
John Rofrano
Re: I cannot move or resize a frame after using the mask option in Event Pan/Crop
on Sep 7, 2015 at 11:19:35 pm
[Valerio Alves] "Does anybody knows how to solve this issue?"
Select the Position keyframe track above Mask. You have Mask select but disabled. If you click the word Position above the word Mask you will have the Position selected and Pan/Crop will be enabled again.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Valerio Alves
on Sep 7, 2015 at 11:31:05 pm
Thanks John, it worked!
I can't believe the solution was so easy... I tried clicking in all possible places in the Event Pan/Crock window, but not in Position keyframe!
John Rofrano
on Sep 7, 2015 at 11:36:50 pm
Yea, it's really subtle, This has gotten me a few times so I remember it now. lol. ;-)
~jr
