Tuning VST plugins don't work when rendering regions with script
COW Forums : VEGAS Pro
Oleg Merkuryev
on Sep 6, 2015 at 4:34:00 pm
I have a pieces in an audio track, which need to be musically tuned and batch-rendered (using regions). While I'm tuning and listening to the track everything works great. Tuning VST plugin (Antares AutoTune or WavesTune) does work.
But as I run a batch-rendering script and listen to the result - it sounds like VST plugin is not applied at all! I've checked other types of plugins - like phaser or even pitch shifter (third party), everything renders just fine with effect applied.
Any ideas how to fix it? Or it's "low-level" problem only SV developers could fix?
John Rofrano
Re: Tuning VST plugins don't work when rendering regions with script
on Sep 6, 2015 at 5:23:38 pm
Waves Tune does not support Vegas Pro. Supported hosts are:
  • Pro Tools 11.0.3 - 12.1 (AAX Native 64-bit, Audiosuite)
  • Pro Tools 10.3.8 - 10.3.10 (RTAS, Audiosuite)
  • Ableton Live 9.1.6 - 9.2.0 (VST)
  • Nuendo 6.5.35 - 7.0.20 (VST3)
  • Cubase 7.5.30 - 8.0.20 (VST3)
  • Studio One 2.6.4 - 2.6.5 (VST3)
Antares AutoTune should work so I would stick with just using that. I don't have that plug-in so I can't help get it working but I just wanted you to know not to bother with Waves Tune because I bought it and had to return it because it wasn't supported with Vegas Pro.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Oleg Merkuryev
on Sep 6, 2015 at 5:26:57 pm
I've tired Waves out of curiosity, when Antares AutoTune wasn't working. I prefer Antares.
John Rofrano
on Sep 6, 2015 at 5:32:39 pm
There seems to be a few tutorials on YouTube on Antares AutoTune and Vegas Pro so you might want to watch some of them and see if those people are doing something different from your workflow.
~jr
