Text editing in SV
COW Forums : VEGAS Pro
Gennady Gaidukevich
Text editing in SV
on Sep 4, 2015 at 11:17:49 am
I have task: I need to make that first fade in text from left side and then text from right side (after “:” sign)
Problem: if I make one text layer then whole text is fading in If I make two separate layers then problem is to adjust text:
https://s.mail.ru/2DrkueCikbCy/img-2015-09-04-14-09-00.png
When I try to move text it moves ALL:
https://s.mail.ru/r2j8q3Lcihda/img-2015-09-04-14-09-32.png
But I need every line to adjust separately
This is what I want (see how smooth it is adjusted): https://s.mail.ru/3TFAWe44c9q3/img-2015-09-04-14-10-20.png
But this is in case if I make text in one layer. But if I make 1 layer then I cant use effect for separate lines cuz it affects them all!!
I can make screencast if u need more details
John Rofrano
Re: Text editing in SV
on Sep 4, 2015 at 1:21:57 pm
You might want to solve this by using a Mask (in Pan/Crop) and two copies of the text. Mask the left side on one copy and the right side on the other. Then fade each one in independently.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Steve Rhoden
on Sep 4, 2015 at 2:06:51 pm
Just follow Johns direction, its not a complicated task as you are thinking.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
