Sony Vegas problem with previewing a mp4 video.
COW Forums : VEGAS Pro
Stanislav Petrov
on Sep 3, 2015 at 8:33:30 am
Hello guys, it's the first time I have come across such a problem.Yesterday i started editing a video but vegas wouldn't let me preview my whole video. I'll try to be as clear as possible. Here's the case: The video i wanted to edit is recorded with 300fps and is 11seconds long.After i started previewing it in vegas it was like slow-moed and ended somewhere in the middle of the video(let's say half of the video was cut off).The funny thing is that when i click on the video in vegas it shows me that the video is the same lenght as the original file(11s).The project settings i used were with 60fps and i tried increasing the fps, but it didn't work.I've been trying to fix this problem for a day now and i can't find the solution to it.I will be really thankful if i receive some help.
Have a nice day and thanks in advance! :)
Wayne Waag
Re: Sony Vegas problem with previewing a mp4 video.
on Sep 3, 2015 at 3:28:04 pm
Try this--disable resampling for your event. Right-click event, select switches, and then select "Disable Resample". This will have Vegas select every 5th frame and not try to calculate an average if "smart resample", the default, is selected.
wwaag
Stanislav Petrov
on Sep 3, 2015 at 6:28:36 pm
Thanks for the quick reply but unfortunately it didn't work.I'm still trying to figuire it out.
Ryan Graves
on Sep 3, 2015 at 3:50:14 pm
I run into this same issue with footage shot on my iPhone 6 Plus - it's at 240fps and I need to drop the velocity down to 10% or so in order for the footage to actually be the crisp, clear slow motion shots that I filmed it in. Try that and then re-render.
Sincerely,
Ryan Graves
Seattle Wedding Videography
http://www.seattleweddingvideography.com
Steve Rhoden
on Sep 4, 2015 at 6:32:15 am
That is due to the high 300fps.
Does it render out ok and as expected?
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Stanislav Petrov
on Sep 4, 2015 at 7:29:03 am
No, the rendered video is exactly the same as the vegas video (half video), although i've never had such an issue with 300fps and even higher videos(I used to edit some very high fps videos) and it's not the video itself, because i sent it to a friend, who said that it was being previewed by vegas properly (with a 60fps project setting).
Steve Rhoden
on Sep 4, 2015 at 2:03:22 pm
Well then im not sure what could be the problem, because the problem
as you state is not with the file or with Vegas, then its something
on your system throwing things off, like a codec issue or something.
Stanislav Petrov
on Sep 4, 2015 at 3:04:35 pm
You could be right because i'm having the same issue with other videos of the exact same type. However, it doesn't happen with .avi videos for example.What should i do? Reinstall the codec or something? Sorry, i'm not really that much into computers :). Thanks!
Wayne Waag
on Sep 4, 2015 at 3:30:33 pm
When all else fails, try posting a screenshot of your media properties, project and render settings as well as your timeline. Even better, you can upload a sample to Dropbox or something so that others can have a look at the actual file.
wwaag
Stanislav Petrov
on Sep 4, 2015 at 9:55:49 pm
http://puu.sh/k03Pu/39301b0805.png
http://puu.sh/k03Rs/12c20b76fd.png
I don't think the render settings would affect my video in any case.
Steve Rhoden
on Sep 4, 2015 at 9:26:04 pm
For starters, you could provide us with the exact details of the format
of this file and the exact source of where it came from.
Stanislav Petrov
on Sep 4, 2015 at 9:56:48 pm
Here's some extra info.
Wayne Waag
on Sep 4, 2015 at 10:17:58 pm
According to your media Properties screenshot, your source is 100 fps, not 300 fps, in which case, your render settings would be very important. Getting from 100fps to 60 fps will be problematic regardless. Have you tried changing your project properties to 50 fps, the PAL standard. In that case, it would be much easier for Vegas to do the conversion from 100 to 50, especially by disabling resampling which would just drop every other frame. Again, you can always upload the video for others to have a look if need be.
wwaag
Danny Hays
on Sep 4, 2015 at 6:23:41 pm
I was able to edit a 300 fps video using the Lagarith codec. Have you tryed it yet?
http://lags.leetcode.net/codec.html
Danny Hays
Samples of my Work can be seen here:
https://www.youtube.com/user/ErnestDaniels/videos?view_as=public
chris king
on Nov 3, 2015 at 9:00:48 am
Would it caused by the video codec contained with your MP4 videos. What you need is to directly find a proper codec that Vegas can handle or convert MP4 to Sony Vegas compatible video codec.
