Internet 720
COW Forums : VEGAS Pro
Thayalan Paramasawam
Internet 720
on Sep 1, 2015 at 12:49:17 am
i render my project for youtube using mainconcept AVC/ACC.After i render....my file size is to large (1.9gb) and its take a hours to upload.How reduce my file size with good quality.
Details
Footage - 29 minutes long
Project Setting - 1920X1080 50p
Render Setting - Internet 720 (default Setting - i never change any setting)
Pls help me on this matter...very urgent
Thank You
http://www.jptsskyvision.com
System Details:
Motherboard - Asus M5A99X-EVO,HardDrive1 boot C:SSD Kingston,Processor - Amd FX 8350 4.0/4.2 GHZ,Ram - 16 GB,Graphic Card - Asus Gtx 650 1GB DDR 5,Blu Ray Writer - Plextor PX-B950SA,Operating System - Window 7 Pro 64 Bit and Editing Programe - Sony Vegas Pro 12
Steve Rhoden
Re: Internet 720
on Sep 1, 2015 at 1:37:51 am
No, use the Sony AVC Internet 720p template instead.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Re: Internet 720
on Sep 2, 2015 at 4:28:25 am
Thanks Mr.Steve Rhoden
System Details:
John Rofrano
Re: Internet 720
on Sep 1, 2015 at 5:14:39 pm
[Thayalan Paramasawam] "After i render....my file size is to large (1.9gb) and its take a hours to upload.How reduce my file size with good quality."
File size is controlled 100% by bit rate. Lower the bit rate and the file will get smaller. Use the Two Pass option of MainConcept AVC if you need more quality at lower bit rates.
[Thayalan Paramasawam] "Render Setting - Internet 720 (default Setting - i never change any setting)"
The Sony template uses a very high bit rate. Probably higher than you need. I use 3Mbps - 4Mbps for my Boris TV tutorials and they look fine.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Re: Internet 720
on Sep 1, 2015 at 10:46:28 pm
Hi Sir (Mr.John Rofrano)
Mr.John (I use 3Mbps - 4Mbps).Pls check my setting.
Thank You
System Details:
John Rofrano
Re: Internet 720
on Sep 2, 2015 at 12:21:35 am
[Thayalan Paramasawam] "(I use 3Mbps - 4Mbps).Pls check my setting."
That's not the MainConcept AVC encoder. That's Sony AVC. You did set it correctly for 4Mbps but MainConcept AVC will give you better quality at lower bit rates, especially if you use Two Pass (Sony AVC doesn't support this).
~jr
Re: Internet 720
on Sep 2, 2015 at 12:31:01 am
Mr.John Rofrano(AVC will give you better quality at lower bit rates, especially if you use Two Pass (Sony AVC doesn't support this).
1)Sir can you screen shoot me how to set.
Thank you
System Details:
John Rofrano
Re: Internet 720
on Sep 2, 2015 at 12:52:03 am
[Thayalan Paramasawam] "can you screen shoot me how to set."
Then set the Average (bps): to 4,000,000.
~jr
Re: Internet 720
on Sep 2, 2015 at 12:55:54 am
MR.John Rofrano...How about maximum (bps)
System Details:
John Rofrano
Re: Internet 720
on Sep 2, 2015 at 10:52:21 am
[Thayalan Paramasawam] "How about maximum (bps)"
I would set maximum to double the average. This limits how high any one frame can get. You don't want to set it so high that it doesn't play back smoothly but with Internet video I don't think you need to worry as much as for broadcast or DVD.
~jr
Re: Internet 720
on Sep 2, 2015 at 11:29:12 am
Thank you very much Mr.John Rofrano....my probleum solve.
Thank you
System Details:
Re: Internet 720
on Sep 2, 2015 at 9:28:14 am
Thank you very much Mr.John Rofrano....finally my probleum solve...
Thank you
System Details:
Re: Internet 720
on Sep 2, 2015 at 12:38:14 am
Mr.John Rofrano(Boris TV tutorials and they look fine)
Sir pls send me link,now i start to using boris so i need tutorials.
Thank you
System Details:
Re: Internet 720
on Sep 2, 2015 at 4:26:50 am
Thanks Mr.Danny Hays
System Details:
John Rofrano
Re: Internet 720
on Sep 2, 2015 at 10:49:53 am
[Thayalan Paramasawam] "pls send me link,now i start to using boris so i need tutorials."
You go to the Boris FX web site and select Training | Boris TV and then Sony Vegas Pro. Try this link.
~jr
