Sony vegas 13 crashes when opening
COW Forums : VEGAS Pro
martin benjamin
on Aug 30, 2015 at 10:31:04 am
Since I installed windows 10 sony vegas stops working. I tried reinstalling it but that didn't work. I uninstalled quicktime as well but that didn't work either. I hope there is an solution for this.
Problem Description
Application Name: Vegas Pro
Application Version: Version 13.0 (Build 453) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
Fault Address: 0x00007FF78F4AA710
Fault Offset: 0x000000000081A710
Fault Process Details
Process Path: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
Process Version: Version 13.0 (Build 453) 64-bit
Process Description: Vegas Pro
Process Image Date: 2015-06-05 (Fri Jun 05) 14:53:04
John Rofrano
Re: Sony vegas 13 crashes when opening
on Aug 30, 2015 at 4:01:01 pm
Did you perform an upgrade in place of Windows 10 or a clean install? Upgrade in place is never a good idea but I realize that's what Microsoft is unfortunately recommending these days. I would try a clean install instead if you can't solve it any other way.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Steve Rhoden
on Aug 30, 2015 at 5:09:09 pm
If all else fails, try also to update all your drivers (Video card/Audio, etc) Everything...
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
John Rofrano
on Aug 30, 2015 at 5:27:49 pm
[Steve Rhoden] "If all else fails, try also to update all your drivers (Video card/Audio, etc) Everything..."
Oh yea that reminds me. I had a similar problem when I switched video drivers. Vegas Pro immediately crashed. I had to install the old drivers, tell vegas Pro to disable GPU, install the new drivers, then tell Vegas Pro to enable the GPU. Not fun.
~jr
Steve Rhoden
on Aug 31, 2015 at 12:51:26 pm
Any luck?
Bob Peterson
on Aug 30, 2015 at 10:01:43 pm
Famous last words. "There is absolutely no problem in upgrading to Win 10!" I sympathize. This situation has been discussed in several threads over the last few days. It looks like Win 10 is losing the debate. I do hope you get it sorted out so that everything works again.
