Android Phone Clips and frame rate
COW Forums : VEGAS Pro
John Smith
on Aug 29, 2015 at 6:10:51 pm
hi guys I'm new here and have a question. Im trying to make a DVD (PAL) by editing some clips into a small movie taken on an android phone. After I have my project movie down I will use a DVD authoring programme t burn it to DVD.
Problem is the phones shoots them in Variable Frame rate and when I convert my Vegas project to 25FPS it very jerky looking where there is motion.
Is there any way I can fox this or make it look smoother?
Many thanks in advanced for help given.
John
John Smith
Re: Android Phone Clips and frame rate
on Aug 30, 2015 at 1:08:28 am
Thanks Aaron fro the reply.
They are family clips of home movies ect taken on my phone.
Here is the media info of one of the clips they are all in Variable frame rate format as that's what the phone records in. The ones that are around 25 are fine as when I use 25fps pal settings they play ok its just these one like the one below that give the jerky playback and it really ruins the footage to be honest. any help would be great and thanks again in advanced.
Media Info
General
Complete name : C:\Users\Desktop\VIDEO0132.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 41.3 MiB
Duration : 28s 206ms
Overall bit rate : 12.3 Mbps
Encoded date : UTC 2015-08-13 15:02:29
Tagged date : UTC 2015-08-13 15:02:29
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=60
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 28s 196ms
Bit rate : 11.9 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 30.000 fps
Minimum frame rate : 29.940 fps
Maximum frame rate : 30.070 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.429
Stream size : 39.8 MiB (97%)
Title : VideoHandle
Language : English
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Source duration : 28s 208ms
Bit rate mode : Constant
Bit rate : 192 Kbps
Nominal bit rate : 96.0 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 656 KiB (2%)
Source stream size : 656 KiB (2%)
Title : SoundHandle
Language : English
mdhd_Duration : 28206
John Smith
on Aug 30, 2015 at 10:10:58 am
sorry guys but Im not that advanced with video editing yet lol! what is XDCAM-EX and how do I convert to it?
Bob Peterson
on Aug 30, 2015 at 3:14:50 am
One thing I would try is a velocity envelope to adjust the frame rate where necessary. It may generate some missing frames to smooth things a bit. It may not work, but I would try it.
Bob Peterson
on Aug 30, 2015 at 10:03:37 pm
OK. So no one should try something different?
John Smith
on Aug 30, 2015 at 10:55:08 pm
Hi again
I did try both the velocity and the XDCAM but the velocity the clips is too fast and still choppy and the XDCAM is just the same as when I edit it in mp4 format.
John Smith
on Sep 1, 2015 at 11:49:03 am
Ok guys can there is bound to be someone in the world who takes clips with either iPhone or android (HTC ONE Specifically) and edits theme into short family movies with the option then to burn to DVD (PAL) for family members??????
I really need to try to come up with a solution to smooth out this jerkiness I have tried to keep all clips at and vegas project settings at 30fps. This has helped out a lot as when i use convertxdvd to make a NTSC DVD instead of a pal version the frame rate matches and my home DVD players will play both pal and ntsc discs.
The only problem in Vegas is that most of my clips are around 30fps (Varaiable) and some are 25fps (Variable), now before i was making my whole project 25 pal which meant it was frame dropping to match and gives the jerky playback in final render. The reason for this was I dod not know my dvd players would play a ntsc disc.
so I tried the opposite which was making my project 30fps ntsc in vegas and burning the final render to ntsc disc which keeps playback smooth but where the 25 fps clips are inserted I get choppy playback so I cant win either way.
also would i be better using handbrake to keep frame rate of each clip constant before i put them into vegas or can vegas handle better with the raw footage directly from phone???
