Adding graph - Sony Vegas
COW Forums : VEGAS Pro
Tomasz Tomkiewicz
on Aug 23, 2015 at 12:40:43 pm
I'm looking for some way to add graph to movie using Sony Vegas. I want to do something like this (I haven't found another video with that "effect")
Is it possible to do this using Sony Vegas?
BR, Tom.
Bob Peterson
Re: Adding graph - Sony Vegas
on Aug 23, 2015 at 5:35:44 pm
You could create the graph in something like Photoshop. If you want the curves to be progressive on the timeline, they will need to be created separately. Then, you can reveal the curves in one of two way. You can set up a mask to slowly reveal the curves, or you can pan across a wide graph. Either way, use pan/crop with key frames.
