Rendering to GoPro-Cineform Decoder - 2
COW Forums : VEGAS Pro
David Galindo
on Aug 19, 2015 at 9:14:37 pm
I am new to vegas and to cineform. I am learning as I go. My editor is Vegas Movie Studio HD Platinum 11.I read cineform is a better codec to play in NLEs.
I also installed GoPro Studio 2.5.6 to start using GoPro-Cineform Decoder - 2.
I am trying to render a project 720 x 480 with the pixel AR at 1.2121 into an avi container, and encoded in cineform. The original file is also an avi container but encoded with Huffyuv codec.
After rendering, the file resolution changes to 360 x 240 9:5, 1:8:1
If I render in a mov container, the file outputs correctly at 720 x 480. I did few other tests in virtualDub but ended up with the same issue too. It outputs the file to 360 x 240.
Anyone knows the steps to render in cineform in Vegas into a NTSC DV 720x480 in an avi container?
Edit
Seems I am using the wrong media player, which was Windows Media player.
Switched to QuickTime and the video inspector display 720 x 480
Mediainfo displayed the same info too.
Is Quicktime the best player to play cineform files?
Steve Rhoden
Re: Rendering to GoPro-Cineform Decoder - 2
on Aug 20, 2015 at 5:26:43 pm
"I read cineform is a better codec to play in NLEs"
Where you got that info?. Been years since i last tried anything Cineform.
I'm a Pro and never a need to use it.
For one, you are making your editing un-necessarily complicated David.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Aaron Star
on Aug 20, 2015 at 7:52:29 pm
I have to agree with Steve. What are you trying to do, and display to?
VLC player, and rendering your footage to .MXF - DV profile would be the way to display in DV. If DV is what you need to display in. You can also do .AVI - DV profile, its all the same.
GoPros are HD, so converting your footage to .MXF - XDCAM-EX profile would be the most responsive way to edit that material in Vegas.
Steve Rhoden
on Aug 22, 2015 at 7:19:45 am
Quicktime is my preferred format working with, can be sent to anyone, editor,
broadcast House, grandma's home, studios, tv stations, its compatible
where ever it goes, study up on that.
