Vegas Pro 12 not able to read files encoded in Apple ProRes
COW Forums : VEGAS Pro
Rick Shorrock
on Aug 18, 2015 at 9:31:35 pm
I recently downloaded some free files from Rampant Design Tools. Most are MOV files that have been encoded in ProRes. On Sony's site, their FAQ mentions that ProRes-encoded files will work with Vegas 12. There was a link to download the ProRes codec, and I tried to do it, but my computer told me that there was an updated version already installed. But still Vegas is telling me that there is an unrecognizable stream associated with every one of the RDT files that import into Vegas. So what gives?
Bob Peterson
Re: Vegas Pro 12 not able to read files encoded in Apple ProRes
on Aug 18, 2015 at 10:06:03 pm
My guess is that, if you are not using Sony's recommended version of the codec, you will probably not get any support from Sony. In the past, Vegas users had to use an older version of Quicktime to successfully read .mov files. I haven't seen that mentioned recently, but this could be another case of that phenomenon.
Rick Shorrock
on Aug 18, 2015 at 11:30:08 pm
The link I mentioned trying is on Sony's site. Why would they recommend an "unrecommended" version of the codec?
Aaron Star
on Aug 18, 2015 at 11:53:53 pm
I would look at the "Media Info" (the application) on the ProRes files and make sure the Writing Library was Apply. If not they may have use FFmpeg to encode Prores and screwed it up.
Next try the Vegas 13 Trial and see if that plays the file in question.
John Rofrano
on Aug 19, 2015 at 3:10:38 am
I use Apple ProRes files in Vegas Pro all the time and it reads them just fine. You no longer need to download the codec because the decoder is now part of Apple QuickTime for Windows.
I went to Rampant Designs and downloaded some of their free QuickTime files and I can confirm that they do not work with Vegas Pro. So there is nothing for you to do but complain to Rampant Designs or convert them to some other format yourself.
BTW, these files work perfectly fine in Final Cut Pro X and appear to be valid ProRes 422 files from the Apple encoder. If I run them through Apple Compressor on my Mac and drop them back into Vegas Pro they play perfectly. So it's something with how Rampant Designs is encoding the files that is causing them not to work with Vegas Pro. I would hazard a guess they they don't even test their QuickTime files with Vegas Pro so it should be no surprise.
You could also complain to Sony because FCP X doesn't have a problem reading them and therefore Vegas Pro shouldn't have a problem either but the fact that running them through Compressor to make new ProRes 422 files works with Vegas, kind of points to Rampant Designs as the source of the problem.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Rick Shorrock
on Aug 19, 2015 at 11:38:57 am
Thanks, John. I knew if anybody, you would know what's going on!
John Rofrano
on Aug 19, 2015 at 1:00:10 pm
You're welcome Rick. It's really strange because the files appear to be "real" Apple ProRes 422 and work fine on my Mac. Which, by the way, is one of the primary reason's I moved to the Mac. I got tired of Windows not being able to work with industry standard files. ;-)
~jr
Rick Shorrock
on Aug 19, 2015 at 2:25:47 pm
Any free programs you might recommend to convert the files to something that will work in Vegas? Streamclip, perhaps?
John Rofrano
on Aug 19, 2015 at 3:11:20 pm
[Rick Shorrock] "Any free programs you might recommend to convert the files to something that will work in Vegas?"
I really don't know because I would use Apple Compressor on my Mac to deal with it. I would try Streamclip and see if it works.
BTW, from past threads on this topic, we learned that Adobe Media Encoder creates ProRes files that Vegas Pro cannot open so perhaps Rampant Design is using Adobe Media Encoder to create these files. I'm sure Adobe would consider this a "Sony problem". lol
~jr
Steve Rhoden
on Aug 19, 2015 at 6:02:21 pm
A distinct ploy by them John, lol.
Anyway Rick, i too run into problems with some files from Rampant
in this similar regards. I use after effects to convert them to what i want.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Wayne Waag
on Aug 19, 2015 at 9:54:36 pm
[Rick Shorrock]
Just downloaded one of the freebies and confirmed that it will not open in V13. I found 2 ways to easily convert to MP4. First Photoshop CC, although it's really slow. You can also convert to Apple Animation in PS, which is even slower. Second, and free, is Handbrake. Surprisingly, it opened without any problem and I was to able to render pretty quickly to a high bit rate MP4. Both the files from Photoshop and Handbrake opened in Vegas without issue. Only thing I could see different is that chroma sub-sampling was reduced from 4:2:2 to 4:2:0. Also in both instances, you will need to apply a Studio to RGB conversion to bring it back to 0-255. Apple Animation rendered at full scale, but don't know if chroma subsampling was maintained.
wwaag
Wayne Waag
on Aug 19, 2015 at 10:44:04 pm
Even better (also free), you can open a one line Avisynth script in Virtualdub, use the UT Video lossless codec, selecting the YUV422 BT.709 VCM preset and the resulting file should be identical to the orginal ProRes file. Rendering is pretty quick.
wwaag
Steve Rhoden
on Aug 20, 2015 at 1:59:03 am
Handbrake is the best free option to choose!
Rick Shorrock
on Aug 20, 2015 at 2:20:11 am
I ended up using MPEG Streamclip as a workaround. I imported a clip, using the 'Export to QT' settings, I used the Avid DNxHD codec, changed the color space to RGB and rendered the file uncompressed. I was then able to drop the resulting clip in a track over my main video track in Vegas, and using track motion on the upper track and then picking 'screen' as the overlay method, which rendered the black background clear. These are mainly effects tracks like lighting, bokeh and flares that I'll convert as I need to.
John Rofrano
on Aug 20, 2015 at 3:57:57 am
Glad you found a solution. Avid DNxHD is a good digital intermediary codec to use.
~jr
Steve Rhoden
on Aug 20, 2015 at 5:13:59 pm
That is good!
