Sony Vegas Sliding effect?
COW Forums : VEGAS Pro
Wesley Tong
on Aug 18, 2015 at 4:16:07 am
Is there a way to make a sliding effect? I'm not talking about the transition, i mean as if you slide an object across the floor and it slowly comes to a stop? I tried to use the transition but that moves at a constant rate, and i don't want to have to put multiple keyframes to get the effect either.
Graham Bernard
Re: Sony Vegas Sliding effect?
on Aug 18, 2015 at 4:40:46 am
You can add a Transition Envelope and have the slooooow down. Or even reverse.
Grazie
Wesley Tong
on Aug 18, 2015 at 6:17:46 am
that appears to only work if the item is a video, but im trying to use a still image
Wesley Tong
on Aug 18, 2015 at 6:23:28 am
ok, i have figured it out, i no longer need help
Graham Bernard
on Aug 18, 2015 at 6:28:12 am
Wanna share?
G
Wesley Tong
on Aug 18, 2015 at 6:34:24 am
I'm bad at explaining but i'll try my best. by using either pan crop or track motion, place the images from where you want to move it like you normally would. then right click the keyframes and set it to slow. this is the video i found that helped me on that
