fading one video into another
COW Forums : VEGAS Pro
Mike Dodge
on Aug 9, 2015 at 9:07:27 pm
I have been able to fade one video into another if they are 2 different tracks. But now I want to fade one video into another on the same track. If I but them right up next to one another, I can fade the first to black, and then the second will fade in. If I overlap them, that fade I set goes away. I want to fade the first partially to black and then start fading in the second video. How can I do that?
Thank
Mike
John Rofrano
Re: fading one video into another
on Aug 10, 2015 at 12:31:57 am
[Mike Dodge] "I want to fade the first partially to black and then start fading in the second video. How can I do that?"
As you have seen, trying to add individual fades doesn't work because as soon as you place the two clips together the fades disappear. You must leave at least 1 frame between them for them to stay. If you want to fade to black and back it's much easier to overlap your events and use the Dissolve transition with the Fade Through Black preset.
~jr
http://www.johnrofrano.com
http://www.vasst.com
James Houghtaling
on Aug 11, 2015 at 2:07:45 am
You can always use a Solid Black generated media on the track above - set the level to semi transparent and fade it in and out as desired.
My Hardware:
Core i7-5960X 3GHz; Nvidia GTX980, 16 gig RAM Win7 64bit.
My Software:
Vegas Pro V11 with Boris Continuum Complete 8, VASST Ultimate S; Bluff Titler; AE5; PhotoPaint and other stuff.
