Render loop region only
COW Forums : VEGAS Pro
Thomas Reget
on Jul 28, 2015 at 9:22:21 pm
The "Render loop region only" has suddenly become muted in Vegas pro 9 on my travel laptop. Any suggestions as to unmute?
Sarah Conner
Re: Render loop region only
on Jul 28, 2015 at 10:07:43 pm
Did you check to make sure you're not forgetting to select a loop region on the timeline?
Should look like this.
Thomas Reget
on Jul 28, 2015 at 10:11:24 pm
Yes, loop region is selected, I've been rendering a bunch of short clips for a couple days, and it suddenly muted the check box.
Danny Hays
on Jul 28, 2015 at 10:37:27 pm
I would try opening a new project, add a small clip, set some loop points, and see if the "render looped region only" box is accessible. If not, I don't know anywhere in the preferences to enable, disable that. Try a system restore to before where this started happening. If that doesn't work, try uninstalling Vegas and re-install it.
