Vegas Pro 13.0 freaks out when dealing with things a little too much for it
COW Forums : VEGAS Pro
Smile Wide
on Jul 27, 2015 at 5:03:17 am
Lets say i put a gif in the video track with rainbows flashing, and a few pictures on top of it spinning. the video starts flickering at that point and goes insane. Sometimes even crashing and causing some files to corrupt. halp me pls :c
Graham Bernard
Re: Vegas Pro 13.0 freaks out when dealing with things a little too much for it
on Jul 27, 2015 at 8:07:45 am
[Smile Wide] "halp me pls :c"
Sure.
1] Project Setup
2] GIF Media Properties
3] Photos Properties
4] Your system Specs
5] CODECS Installed on your System
All these things are essential to know to allow us to assist.
Grazie
Smile Wide
on Jul 27, 2015 at 7:54:55 pm
1) Project setup:I don't really know how i do this one
2)GIF Media Properties:2.58 MB
3)Photos Properties:667 bytes (667 bytes)
4)System Specs:Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 3.40Ghz XPS 8500
Windows 7 64 bit
Dell
XPS 8500
DirextX11
AMD Radeon HD 7770
5)Codecs:Windows media player, Quicktime
The thing is, this happens with greenscreens and animations, and it also comes out with the weird flickering glitches when i render it too. So it kinda gets corrupted but it isnt corrupted :c
Bob Peterson
on Jul 28, 2015 at 2:04:05 pm
It sounds like you have several things going on at once. I suggest that you stop everything. Then, add items back one at a time. After each addition, test to see if everything works OK. If it is OK, add one more thing. Keep adding things back until one finally causes a problem. Report back as to exactly what that one thing is.
Smile Wide
on Jul 28, 2015 at 7:40:50 pm
its the GIFs and green screen effects that cause these, anything with like animation kind of thing that causes these problems. since i insert the original base event what my video really is about, and i click the base the settings on first clip. So i believe that's what happens. But i dont know how to fix it.
