Weird box shows up when using Yellow Cookie Cutter
COW Forums : VEGAS Pro
John Lee
on Jul 21, 2015 at 2:04:13 am
I make sports highlight videos and I like to pause the video at times and put a spotshadow on a person. I'm sure there are better methods, but what has been working for me is the following.
I play the clip until the desire spot. Then I cut the clip and save the image. I'll then reinsert the .png image into the video timeline where I had made the cut in the video. Then I paste the same .png on the video track above so that I have two still images on top of each other. On the top layer, I then go to Video FX, Cookie Cutter, and Yellow Glowing Portrait. After I move the cursor over the .png file, I'll move/resize the yellow circle around my subject. Has always worked great every time.
Now I'm seeing something weird. When I move the yellow circle, the image looks fine until I move the yellow circle over the center of the image. There is a rectangular section that appears OVER the circle when I pass through it. When I close out of Video FX, the circle (if it was over this new rectangle) still appears behind it.
I've never seen this before. I don't think I changed any settings, but it's weird. What am I doing wrong?
And is there a better way for me to have a nice visible spotshadow rather than the method I described above?
Thanks.
John Lee
Re: Weird box shows up when using Yellow Cookie Cutter
on Jul 21, 2015 at 2:46:38 am
Sorry, I meant Yellow Glowing Portrait on Cookie Cutter.
Bob Peterson
on Jul 21, 2015 at 2:55:35 am
I'm having to guess at your settings, but still not seeing a problem.
Bob Peterson
on Jul 21, 2015 at 2:51:17 am
I duplicated what you described in SVP 12. I did not see the phenomenon that you describe. Do you have a transparent area in the png? I'm wondering if something like that could cause what you are seeing.
