Preview window does not change with timeline cursor (Vegas 11.0)
COW Forums : VEGAS Pro
Sharon Lee
on Jul 20, 2015 at 1:34:58 am
Hi, I believe my problem is similar to this one (https://forums.creativecow.net/thread/24/980012) but it seems like this person's problem wasn't fixed.
When I click around with my cursor on the media, the preview window doesn't change to show the video at its new location. Also when I use my arrow keys to move frame by frame, the preview window doesn't change.
But when I press Play, it will play as normal.
Anyone have any ideas? I know for sure that there is nothing wrong with the media since I've used the same media on Vegas 11.0 but on a different computer.
John Rofrano
Re: Preview window does not change with timeline cursor (Vegas 11.0)
on Jul 20, 2015 at 11:35:28 am
Are you using the Trimmer? In some version of Vegas Pro the trimmer shares the preview window and you may actually be seeing the trimmer output instead of the timeline output. The behavior was changed from version to version so I'm not sure if Vegas 11 was one of the versions that confused people with this behavior. Try closing the trimmer and see if it fixes the problem.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Sharon Lee
on Jul 20, 2015 at 2:04:17 pm
Hi John, thanks for your reply. I did try closing the trimmer (through View -> Uncheck Trimmer) but nothing has changed.
John Rofrano
on Jul 20, 2015 at 3:04:15 pm
Can you post a screen shot of what you are seeing? maybe there is something someone can spot?
~jr
