Sony vegas Pro 13 play button doesnt work
COW Forums : VEGAS Pro
Harry Smith
on Jul 11, 2015 at 10:23:26 pm
I have encountered what seems to be a bug on Sony vegas Pro 13. My play button doesn't work at times. The marker on the timeline doesn't move across either. I have tried to use diffrent buttons to play the video but it still doesn't work. The strange thing is if i just close sony vegas and re-open it i can press play no probem. I have no idea what the problem is, can anybody help?
John Rofrano
Re: Sony vegas Pro 13 play button doesnt work
on Jul 12, 2015 at 12:10:14 am
Sometimes this happens because Vegas Pro cannot play the audio. If, for example, some other software has locked your audio device at 44.1KHz and Vegas Pro is trying to play pack at 48KHz (it's default) the timeline will not play because the audio device can be switched into 48K mode. Check that the audio setting of your project and the audio settings of your audio device match.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Graham Bernard
on Jul 12, 2015 at 2:13:11 am
This is an unfortunate and frustratingly intermittent play back kludge-bug. I and others who've experienced this and use ASIO Drivers, for an external Audio box, have reported this. I can go for weeks and not have an issues, but then, with the same project the 44<>48 "switcharoo" happens and I need to manually reset. Silly.
Grazie
Harry Smith
on Jul 12, 2015 at 3:06:54 am
Thanks for replying and yeh the bug is really annoying, but what do you when you say manually reset?
Graham Bernard
on Jul 12, 2015 at 3:12:18 am
Preferences > Audio Device > ASIO ( for me that's my AudioBox PreSonus) APPLY:
G
Harry Smith
on Jul 12, 2015 at 11:46:40 am
the only device i can select is microsoft sound mapper
Harry Smith
on Jul 12, 2015 at 3:05:14 am
Thanks for the reply. So ur saying i have to change the sample rate of the video?
Graham Bernard
on Jul 12, 2015 at 3:10:29 am
Sample rate of the Audio.
G
John Rofrano
on Jul 12, 2015 at 1:54:19 pm
Try changing the Audio sample rate in your Project Properties from 48K to 44.1K just to see if it's audio related. I assume you are just using the default audio chip on the motherboard which is shared by the rest of Windows and unfortunately the Windows sounds are recorded at 44.1 but audio for video is 48. Normally the chip switches back and forth between the two rates without a problem but sometimes a program running the the background may lock it down to 44.1 causing it to not switch to 48 and then Vegas cannot play it's audio. I would not keep your project at 44.1. It should be 48, but this is just for debugging purpose to see if it could be audio related.
~jr
Harry Smith
on Jul 12, 2015 at 2:16:52 pm
it was at 96k and changed it to 44.1 but it still happens. Sometimes i don't even have a project open and i can't press play. When it stops working, i can go on 'undo' or 'redo', or delete the project and put it back in and it can then play at times which is quite strange
John Rofrano
on Jul 12, 2015 at 2:54:27 pm
[Harry Smith] "it was at 96k and changed it to 44.1 but it still happens."
What if you change it to 48K which is what it should be?
~jr
Harry Smith
on Jul 12, 2015 at 3:00:00 pm
yes, i just changed it to that and i think you have solved it. Thanks a lot :D
Just edited this post now as its still playing up , seems to do it less often but still doesn't work at times
John Rofrano
on Jul 12, 2015 at 10:31:37 pm
At least you now know that it's an audio problem. ;-)
~jr
Harry Smith
on Jul 13, 2015 at 10:37:31 am
true :) i asked somewhere else and they said prehaps my PC isn't powerfull enough to run vegas pro 13, so that may be the problem
John Rofrano
on Jul 13, 2015 at 10:52:39 am
[Harry Smith] "they said prehaps my PC isn't powerfull enough to run vegas pro 13, so that may be the problem"
well... How powerful is it? What CPU? How much RAM? How much free hard drive space? etc. We can tell you if it meets requirements.
~jr
Harry Smith
on Jul 13, 2015 at 4:02:20 pm
4GB Ram, CPU G3220 3.00 GHz, over 400GB free hard drive space. Not the best PC so i will be looking to upgrade soon, especially since its difficult to render out videos and upload them to youtube
John Rofrano
on Jul 15, 2015 at 1:26:33 am
[Harry Smith] "4GB Ram, CPU G3220 3.00 GHz, over 400GB free hard drive space."
Yea, that's only a dual-core. If you get a Core i7 and more memory you'll see a big difference. Probably 3x faster.
~jr
Harry Smith
on Jul 15, 2015 at 3:09:57 pm
looks like im going to have to sell this PC and put the money towards a new one then
Eric Taylor
on Sep 19, 2016 at 4:17:06 pm
Harry I had the exact same problem and finally figured it out. Might be the same problem as you. turns out my speakers were turned off on my computer, so when sony tried to play a sound it just froze. Nothing! I "solved" this by plugging in my earphones into the audio jack of the computer.
You would think if the computer detected no sound device sony would I dunno either tell you there's no sound keep working or print an error message but nope just freezes up.
So try plugging in your earphones might help.
