After rendering, the video output becomes dual / split screen?
COW Forums : VEGAS Pro
Jovic Trinidad
on Jun 14, 2015 at 1:41:52 am
Video preview in my Vegas shows a normal video being rendered, but after rendering, the video output shows a split video with the my video being replicated on both sides. .wmv is the file format.
I do not want a split screen or a side by side video. I just want a normal video output.
Graham Bernard
Re: After rendering, the video output becomes dual / split screen?
on Jun 14, 2015 at 2:37:21 am
Very odd. Need to see a ScreenGrab of your WMP output. What Template are you using? Have tried to bring it back into VP? What do you see in Preview? Can you try it in another Player, maybe VLC Player?
Odd....
Grazie
Bob Peterson
on Jun 14, 2015 at 6:20:40 pm
Does your rendered output look like this;
unclick the split screen button.
Note: the button is also called the "FX bypass" because it can perform either function.
Graham Bernard
on Jun 14, 2015 at 6:54:02 pm
I would have agreed with you Bob, 'cept our chum says that it Previews correctly, in which case I can't see how the FX bypass would be part of the issue.
Grazie
Bob Peterson
on Jun 14, 2015 at 8:20:16 pm
You are right Graham. I missed that part of the message.
Edward Troxel
on Jun 14, 2015 at 7:37:08 pm
Could you be rendering in side-by-side 3D mode?
Edward Troxel
