3-way split screen? (Recording a portrait-mode mobile game)
COW Forums : VEGAS Pro
Joseph Hill
on Jun 11, 2015 at 1:23:34 am
Hey, everyone.
I'm going to be recording gameplay for a mobile game.
The problem is; it only takes up a third of the width of the screen.
I'm wanting to add the clip on either side of the main clip - and blur them.
If that's not possible. Just enlarge and blur the same clip to cover the blank background.
Is this possible? I've had a play around with the pan gimmick. But, I've had no luck. It just seems to zoom in, but doesn't increase in width.
If anyone could help. I'd massively appreciate it.
Apologies if this is a noob question.
I'm using Sony Vegas 10.
Joe.
John Rofrano
Re: 3-way split screen? (Recording a portrait-mode mobile game)
on Jun 11, 2015 at 2:40:42 am
[Joseph Hill] "Is this possible? I've had a play around with the pan gimmick. But, I've had no luck. It just seems to zoom in, but doesn't increase in width."
if you really want a 3 way-split I show you how to do a 2-way split in a tutorial on my web site and you can extrapolate from that how to do the 3rd split. Here is the tutorial:
Creating a Split Screen using a Mask
Personally, it's easier to just place an enlarged blurred version on a track below.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Joseph Hill
on Jun 11, 2015 at 2:36:51 pm
Hi, John. Thanks for the reply.
I'm using Sony Vegas 10.0 Platinum. From what I've read. I'm not able to use the mask function.
Is there any other way of enlarging the video, to fill the screen?
Mike Kujbida
on Jun 11, 2015 at 2:41:52 pm
Joseph, see if this works for you.
Add a new copy of your video to a track below the existing video. Open the Pan/Crop window, right click in the center of it and choose Match Output Aspect. It should fill your screen. Exit Pan/Crop. Add a Medium Gaussian blur to the lower track. If Medium isn't enough, increase the blur amount.
I hope this helps.
Joseph Hill
on Jun 11, 2015 at 2:52:36 pm
Cheers, Mike! You're an absolute hero!
Saved me going out and buying new software!
Thanks again.
Joe.
Mike Kujbida
on Jun 11, 2015 at 3:03:54 pm
Joe, I'm glad my solution worked for you. I often use this technique if I have stills that were shot in portrait mode and I need to see the entire image instead of a cropped one.
John Rofrano
on Jun 12, 2015 at 4:34:32 am
[Joseph Hill] "I'm using Sony Vegas 10.0 Platinum."
No. You are using Movie Studio 10 Platinum. Calling it Sony Vegas 10 will just confuse people into thinking you are using Vegas Pro 10 and give you the wrong answer to your questions. If you are using Movie Studio, you should state that in your post so that we don't recommend solutions that won't work.
~jr
