Scrip for lengthening event in two times
COW Forums : VEGAS Pro
leaning less
on Jun 8, 2015 at 9:53:55 pm
It may loop event. Is there a such script?
Bob Peterson
Re: Scrip for lengthening event in two times
on Jun 9, 2015 at 2:03:52 am
Do you mean that you want to double the time that an event is seen, and that a loop would be acceptable? If that is what you mean, a script is unnecessary. Simply drag the right border of an event, and pull it right to cover the desired time period. The item will repeat just as if it was looping.
leaning less
on Jun 9, 2015 at 7:42:01 am
I deal with great amount of events and that's why I need special hotkey for such action.
Edward Troxel
on Jun 14, 2015 at 7:38:31 pm
Excalibur and, I'm sure, most all other 3rd party scripts can certainly do this.
Edward Troxel
David Eon
on Jun 16, 2015 at 4:22:16 am
Vegasaur's Quick Properties has an event tab that you can set playback rate to .5 and check the "adjust length". You can apply it to all your events at once! Let me know if that helps. Thanks!
DavidEon
