Create DVD Folder With Sony Vegas
COW Forums : VEGAS Pro
Joshua Jackson
on Jun 6, 2015 at 7:43:19 pm
Hello...
I've been using TMPGEnc Authoring Works 4, for years.
I use it to create a DVD folder (VIDEO_TS).
Then, I use Nero Burning ROM 2015, to burn.
Nero supports burning to an image file and to multiple writers.
I started using Vegas for creating .mp4 versions, of these videos.
I figured it would make sense to use Vegas for the DVD creation.
Thus-far, I've only seen the ability to create .mp2 files or burn a physical DVD.
Is there a way to create the DVD folder, with Vegas?
The only, reasonable, option, that I've seen, is to burn a DVD and extract the files.
Thanks for any direction...
JJ
Bob Peterson
Re: Create DVD Folder With Sony Vegas
on Jun 6, 2015 at 8:35:07 pm
These days, Vegas Pro comes with DVD Architect included. The directory you are looking for is created by DVD Architect when it prepares the files needed to create and burn a DVD. Vegas creates various types of video and audio files that can be used directly for playing on a PC, uploading to Youtube, or by programs like DVD Architect which creates DVDs of various kinds. Vegas may, for example, place the video in an mpeg-2 file, and the audio in an AC3 file. DVD Architect then uses these two files to build a DVD. Part of that building process is creating the VIDEO_TS directory. The ability of Vegas to burn a DVD is probably a holdover from its earlier days, and is probably not used very much since it is a very limited function.
John Rofrano
on Jun 11, 2015 at 2:37:35 am
[Joshua Jackson] "Is there a way to create the DVD folder, with Vegas?"
No. As Bob pointed out, you can burn a DVD from the timeline or create a VIDEO_TS folder with DVD Architect but there is no way to create just the folder with Vegas Pro alone (without burning).
~jr
http://www.johnrofrano.com
http://www.vasst.com
