Rendering Problems: Dark Contrast Colors - Pixelation
COW Forums : VEGAS Pro
Reiz Malovelli
on Jun 5, 2015 at 7:42:00 am
I want to start recording videos as a hobby, currently I use Fraps to record (always 60fps full size) and Sony Vegas 13 to edit and render my video, I have had many problems for a few months now. I have looked in so many places for fixes, tried many different render settings and tweaks my sony vegas but no success. I want to fix this problem so I can finally record videos without having to worry about quality issues, I need them solved!
My first issue is the Contrasting of the rendered video, I've adjusted so many settings for this, here was the original coloring that I was getting
but after looking around for tweaks, I finally found an adjustment which made it a lot better (still not perfect, but better) which gave me a result like this
- I achieved this by added a Computer RBG to Studio RBG levels adjustment setting onto the video, this is the best temp fix I found but if I could balance the colors and make them a little softer it would be perfect! in my video preview box at the top right in Sony Vegas has the perfect video color settings I want but I turns out so much different :( (heres a screenshot) http://i.imgur.com/R5M3xJh.png
The second issue is (you can probably already tell from the video) is the pixelation that you can see happening through out the video
I have tried so many different render settings with different bitrates, frames, and just general settings but all come with a similar outcome, sometimes I do get screen tear when I'm recording in fraps so I'm not sure if that might be the problem but sometimes I record fine without screen tear and I still get the same problem.
I'm aiming to get video quality like this guy:
(I know he is using shader mods and cinematics) but his overall quality is amazing, he just really good quality at standard 480p and amazing quality at 720p and 1080p
I would really appreciate any possible help with my problems,
Thanks in advance!
