Vegas 10 pro transitions only applied two in a row and then skips one.
COW Forums : VEGAS Pro
Karel Walters
on May 30, 2015 at 11:59:24 pm
I import 24 images, drop them on the time line, select all on time line, drag transition to first point were images meet. The result is two clips have the transition, skips one, transitions is applied to two clips, skips one so on to the end of the batch of images. I can not force a transition at the skipped point. Can not even drag to overlap. The images are 30 seconds each.
Karel Walters
Re: Vegas 10 pro transitions only applied two in a row and then skips one.
on May 31, 2015 at 1:59:28 am
Found the culprit. Changed new still image to 30.014 seconds or 900 frames per image. Fixed it.
