Spinning visuals without moving around the screen
COW Forums : VEGAS Pro
Shay Jone
on May 30, 2015 at 11:54:47 pm
So basically I have this 3D source alpha at this angle
http://gyazo.com/dd8142e43f9a2ed7fcc07faf2041e325
and I want it to spin right or left but without it moving around the screen. So basically not moving up down left or right but rotating. Any way I can do this using track motion?
Andrew Lenczycki
Re: Spinning visuals without moving around the screen
on Jun 1, 2015 at 4:01:22 pm
Use Track Motion, changing from Source Alpha to 3D Source Alpha and then add Key Frames, changing the Rotation: Y axis to whatever values you want.
Andrew Lenczycki
