Vegas Pro 13 problem
COW Forums : VEGAS Pro
Dan Dajamo
on May 29, 2015 at 8:51:13 pm
I've just started using Vegas Pro to edit video to upload to youtube.
I have one video edited and ready to render, but when I click render i believe its trying to render the FULL video, instead of what i have cut out of it.
Finished edited time is about 12 minutes, and before i edited the video was almost 40.
I think its trying to render the full 40 minutes instead of the 12, how do i fix this??
Thank you!
John Rofrano
Re: Vegas Pro 13 problem
on May 30, 2015 at 1:37:26 am
[Dan Dajamo] "Finished edited time is about 12 minutes, and before i edited the video was almost 40."
Unless you check the option to only render a timeline selection, Render will render the entire timeline. Your timeline should only be 12 minutes long so normally this isn't a problem. If you have other unused video on the timeline, remove it so that you timeline only contains the video you want to keep.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Bob Peterson
on May 30, 2015 at 3:43:21 pm
To avoid this problem, I ALWAYS mark a beginning and ending point for the render. Position the cursor at the begging of the video, and press the "I" key. Position the cursor at the end, and press the "O" key. Be sure the render option "Render loop region only" is checked, and you are good to go.
Dan Dajamo
on May 30, 2015 at 4:05:01 pm
I will be sure to try that!
Thank you for your reply!
Dan Dajamo
on May 30, 2015 at 4:04:18 pm
I looked and didn't see an option of the sort, but I will check again and look a little harder!
John Rofrano
on May 30, 2015 at 10:38:12 pm
[Dan Dajamo] "I looked and didn't see an option of the sort, but I will check again and look a little harder!"
You need to fist make a loop region on the timeline for that option to become enabled:
~jr
Komal Gull
on Jul 1, 2015 at 3:36:17 pm
gr8 thanxx
Danny Hays
on Jul 1, 2015 at 7:23:37 pm
John beat me to it. You can just drag your curser over the time line time count to create your loop points as well as the (I) and (O) keys.
