Dxtory causing Sony Vegas 13 to crash immediatly upon import - Lagarith Lossless Codec
COW Forums : VEGAS Pro
Braden Mars
on May 29, 2015 at 8:26:44 pm
Hello! This is my first post on this forum.
Anyways, I have game clip of CSGO recorded with Dxtory with the Lagarith Lossless Codec (.avi file). I pull up Vegas and move the clip into the program. The second the clip hits the program (vegas does not even show a video/audio track outline) the program crashes. To test the codec, I got Bandicam and set it up with the Lagarith codec and that worked fine. I also tried the default Dxtory codec, same results. From my testings I am led to believe its something with how Dxtory records.
Thanks in advance.
Steve Rhoden
Re: Dxtory causing Sony Vegas 13 to crash immediatly upon import - Lagarith Lossless Codec
on May 30, 2015 at 1:22:23 am
Exactly, Vegas does not sit well with acquired files from Dxtory nor with
some other NLE's for that matter, problematic most times.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Braden Mars
on May 30, 2015 at 1:28:31 am
Thank you for the speedy reply. Is this somehow computer specific or something? As in I just happen to not be able to edit dxtory videos on Vegas for some reason or another or is it fixable? I know many people use dxtory with Sony Vegas, in fact a very close friend of mine is doing everything the same as be except for he uses the default Dxtory codec, which as I mentioned before, I have tested. Once again thank you for the speedy reply and giving a peice of your valuable time to me.
