VASST StillMotion question
COW Forums : VEGAS Pro
Bruce Quayle
on May 28, 2015 at 3:05:27 pm
Just wondering if one of the VASST developers could help me find the "Create Overlap" function in the StillMotion interface? I have loaded StillMotion into my Vegas Pro12 software, and I think I can see evidence of the box just below the "Specify Event Length" function, but am unable to open that area of the interface to display the overlap function. I have tried enlarging the window to the fullest extent, but that particular box (Duration and Placement) does not enlarge enough to display that function.
And while I'm on this subject, can I create movement of the still pictures themselves (with a border) across a background, while maintaining the movement within the frame...and can this be done with this app rather than keyframing each pic?
Thanks for your help.
Cheers,
Bruce
John Rofrano
Re: VASST StillMotion question
on May 28, 2015 at 6:37:17 pm
[Bruce Quayle] "I have tried enlarging the window to the fullest extent, but that particular box (Duration and Placement) does not enlarge enough to display that function."
It sounds like you may have increased your default Windows DPI to something other than 100%. Unfortunately, Windows handles this very poorly and StiilMotion only supports standard Windows DPI of 100%.
[Bruce Quayle] "And while I'm on this subject, can I create movement of the still pictures themselves (with a border) across a background, while maintaining the movement within the frame...and can this be done with this app rather than keyframing each pic?"
That can be done with the MotoFoto function of VASST Ultimate S Pro 4. I haven't created MotoFoto as a separate FasstApp yet.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Bruce Quayle
on May 28, 2015 at 9:26:53 pm
Thanks John. You hit it out the park with your windows solution. Pity you don't have the other app available yet. I could have used it. Can't justify the cost of the complete tool kit as I really won't use enough of them. But thanks for the great app I did buy.
Cheers,
Bruce
