24 and 25 fps on same timeline, which fps to choose in rendering ?
COW Forums : VEGAS Pro
Timothée Ferreol
on May 28, 2015 at 1:57:37 am
Hey,
I really believe everything is in the title ^^, if the majority of my footage is 24fps the rest is 25, should I choose to render in 25 fps ? (I believe, so but not sure) and why ?
And if my footage mostly was 25fps, should I render in 24 fps ?
Thanks guys ;)
___________________________________________
If you want to check out my work =) : https://vimeo.com/timof
John Rofrano
Re: 24 and 25 fps on same timeline, which fps to choose in rendering ?
on May 28, 2015 at 12:17:46 pm
24fps is NTSC. 25fps is PAL. Are you delivering to an NTSC or PAL audience?
If you are just delivering to the Internet then I would render in the format that I have the most footage.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Timothée Ferreol
on May 28, 2015 at 11:35:11 pm
All right, thanks for the answer, yes it's for an internet use.
I was just woried to sort of lag my footage while redenring them to a higher fps that they really are.
John Rofrano
on May 29, 2015 at 12:33:15 am
[Timothée Ferreol] "I was just woried to sort of lag my footage while redenring them to a higher fps that they really are."
Yea, I would never render in a higher frame rate unless I was told to by a broadcaster (i.e., you shot in 24p but the broadcaster requires 29.97).
~jr
