Problem with an introduction for my video
COW Forums : VEGAS Pro
Jake Loggie
on May 25, 2015 at 3:25:51 pm
Hello there, I am a You tuber that has just recorded my first video. Its all edited up to a high standard but when i go to put my intro in (using sony Vegas pro 13) it gives me the error 'File C:\Users\Mr Jake\Desktop\Intro.avi could not be opened.' Why would this be? I have looked online and cant seem to find a similar problem. If anybody can fix this problem for it would be most appreciated.
Graham Bernard
Re: Problem with an introduction for my video
on May 25, 2015 at 5:23:54 pm
Where did you get the AVI from?
G
Jake Loggie
on May 25, 2015 at 6:13:47 pm
Sorry i don't understand. However I can tell you I converted the intro which was originally an mp4 that i was reccomended to convert which was done online
Graham Bernard
on May 25, 2015 at 6:24:13 pm
Ok, what is that file's CODEC?
Grazie
Bob Peterson
on May 25, 2015 at 6:30:15 pm
How are you trying to put this file into your project? Are you using "File -> Import -> Media", "File -> Open", or some other command in Vegas?
Jake Loggie
on May 25, 2015 at 6:43:14 pm
I'm doing it with File > Import > Media > Intro
Bob Peterson
on May 25, 2015 at 8:13:11 pm
What did you use to convert the Intro, and what was changed by your conversion? What file format did you convert it to?
Jake Loggie
on May 25, 2015 at 8:15:56 pm
If we just forget the conversion because the problem occurred before it was converted. When i was sent the file it was an mp4, after trying to input it it came up with the error i posted earlier.
Mike Kujbida
on May 25, 2015 at 8:19:52 pm
What does MediaInfo say about the file?
Jake Loggie
on May 25, 2015 at 8:35:54 pm
General
Complete name : E:Intro.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 5.36 MiB
Duration : 9s 363ms
Overall bit rate : 4 798 Kbps
Part/Position : 1
Recorded date : 2015
Writing application : Lavf56.23.106
Comment : http://www.dvdvideosoft.com
Video
Format : MPEG-4 Visual
Codec ID : MP42
Codec ID/Info : Microsoft MPEG-4 v2 (pre-standard)
Codec ID/Hint : Microsoft
Duration : 9s 333ms
Bit rate : 4 433 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 fps
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.071
Stream size : 4.93 MiB (92%)
Audio
Format : ADPCM
Codec ID : 2
Duration : 9s 363ms
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 4 bits
Stream size : 408 KiB (7%)
Interleave, duration : 23 ms (0.69 video frame)
Interleave, preload duration : 128 ms
Mike Kujbida
on May 25, 2015 at 9:07:59 pm
I noticed dvdvideosoft in the comment line. My success in importing videos that utility produces ranges from slim to none :(
You said that you got it from someone. If at all possible, have them send you the original file and not a converted one.
Jake Loggie
on May 25, 2015 at 9:09:13 pm
What file type do you recommend i ask them for?
Mike Kujbida
on May 25, 2015 at 9:13:21 pm
I like MXF (as does Vegas) but without knowing any more details, it's hard to pick one over another.
What format is the original video?
Jake Loggie
on May 25, 2015 at 9:14:47 pm
I was given it as an Mp4
Mike Kujbida
on May 25, 2015 at 9:21:58 pm
Vegas "should" be able to open an mp4 file.
What version of QuickTime player do you have installed on your computer?
Can you have the file sent to you in a different format such as MXF?
Jake Loggie
on May 25, 2015 at 9:23:33 pm
Im not sure what version of quick time I have installed. I can ask to have the file sent as an MFX
Mike Kujbida
on May 25, 2015 at 9:33:16 pm
[Jake Loggie] "Im not sure what version of quick time I have installed."
Launch QT player and go "Help - About QuickTime Player".
"I can ask to have the file sent as an MFX"
Probably your best option as MXF files work very well in Vegas.
Let us know how it turns out. Good luck!!
Jake Loggie
on May 25, 2015 at 9:37:45 pm
Unfortunately I cant get on the PC with Sony Vegas until Saturday, but i will be sure to let you know then!
Mike Kujbida
on May 25, 2015 at 9:38:33 pm
No problem. I hope it all works out for you.
Graham Bernard
on May 26, 2015 at 5:13:13 am
Lesson learnt here:-
**** We need to manage our expectations with Vegas in that we can't assume that getting Media from a 3rd Party will conform correctly allowing Vegas to play *****
Hence my original question and the clear pathway that Mike showed.
Grazie
Jake Loggie
on May 29, 2015 at 4:03:32 pm
What do you recommend I do then? I really need this problem solved.
Here is the origional mp4 video file.
https://reels.creativecow.net/film/original-mp4-introduction
Jake Loggie
on May 29, 2015 at 12:54:04 pm
I have just got back and tried to convert the original file from an mp4 to an MXF although nothing had changed. What do you recommend I do now?
