only 2 min records out of a 22 minute video
COW Forums : VEGAS Pro
edgar gillham
on May 23, 2015 at 12:40:49 am
I created a 22 minute video and ran a preliminary burn on CD-RW, worked fine. I then added text to the video and tried to run another copy, only 2 minutes records. que pasa?
enjoy yourself, it's later than you think.
Bob Peterson
Re: only 2 min records out of a 22 minute video
on May 23, 2015 at 1:33:23 am
Did you have a loop region set up, and opted to render only the loop region? That is what it sounds like. In the "render as" window, unclick the "render loop region only" option.
edgar gillham
on May 24, 2015 at 12:01:32 am
Thank you for the reply. I made no changes after burning the preliminary DVD-RW except to add text, however your suggestion sounds like a good place to start.
edgar gillham
on May 25, 2015 at 4:15:12 am
I checked the above suggestion but that was not the answer, render loop only box was not checked. Any other suggestions?
