Color spaces in Sony Vegas Pro 13...
COW Forums : VEGAS Pro
Seth Kopchu
on May 21, 2015 at 9:00:58 pm
While rendering out a .mp4, I noticed something under the render settings called "Color space". What exactly is it and why are there so many options to choose from for it?
Aaron Star
Re: Color spaces in Sony Vegas Pro 13...
on May 22, 2015 at 5:36:12 am
I would just leave it set to default if you do not know why to change it. Also make sure your set to 8-bit and not 32-bit under project settings.
http://en.wikipedia.org/wiki/Color_space
Higher end video codecs and some effects require rendering in larger color spaces than the default color space. ACES for example is the currently the highest end color space, with simple on or off black and white being the lowest.
