Timline changed. My timeline changed. Dont know how to get back
COW Forums : VEGAS Pro
David Lepage
on May 16, 2015 at 6:44:44 pm
I do not know what I did but suddenly , my timeline is much smaller, There are no "A" and "X" icons and arrows pointing up and down. Does anyone know what I did and how to change it back to what it was?
thanks in advance!
John Rofrano
Re: Timline changed. My timeline changed. Dont know how to get back
on May 16, 2015 at 11:52:50 pm
Posting a screen capture might help. It's hard to understand what you are seeing (or in your case... not seeing). ;-)
~jr
http://www.johnrofrano.com
http://www.vasst.com
David Eon
on May 26, 2015 at 7:22:25 pm
I'm not sure if this is the problem your having, but I often have a similar problem if I double click the beginning of an event it Expands track Layers. The solution is to right click on the layer on the far left side and uncheck Expand track layers...or you can also double click on the beginning of the event again. Let me know if this helps. Thanks!
DavidEon
