Is there a way to add notes to events or a project?
COW Forums : VEGAS Pro
Ron Whitaker
on May 11, 2015 at 2:05:40 am
I noticed on this page:
http://vasst.com/downloads.aspx
That there is a Notepad extension to download. Does this allow you to add notes to a project regarding events or clips?
I'm going through 35 hours of footage for a documentary. I'd like to simply add notes within Vegas to the clips that I'm viewing within the Trimmer Window.
I downloaded the Notepad extension, but it doesn't appear in Vegas. I am running Vegas 13. Is Notepad compatible with version 13? Or is there a better option for including notes regarding clips?
Thank you.
Steve Rhoden
Re: Is there a way to add notes to events or a project?
on May 11, 2015 at 8:58:43 am
Notepad would be a good choice for your task at hand, but unfortunately it hasn't been updated for a while, so it wont work in Vegas 13.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
http://www.facebook.com/FilmexCreativeMedia
Graham Bernard
on May 11, 2015 at 10:07:28 am
[Ron Whitaker] "Or is there a better option for including notes regarding clips?"
Gary James FREE TimeLine Tools works in VP13
Also, have a look at the "Comment" Field in VP13. Add a Comment and you could even search on that and make a BIN - Good; Bad; Downright Ugly!
Grazie
Jorma Nippala
on May 11, 2015 at 10:31:33 am
Steve Rhoden
on May 11, 2015 at 12:34:53 pm
Hey Ron, Have you yet tried timeline tools if it has such a feature, as Graham mentioned?
Jorma Nippala
on May 11, 2015 at 12:48:54 pm
My screengrab link (on CC) above showing Notepad is from Vegas Pro 13 build 310. Notepadinstaller was 1.2.0.exe.
See View > Extensions.
I wonder if the later updates broke it.
Steve Rhoden
on May 11, 2015 at 3:02:24 pm
SORRY, My terrible mistake gentlemen, Notepad does work and install properly
in Vegas 13. Last i checked it wasn't, and not seeing vegas 13 listed in
it's note i figured it still hasn't yet been updated, but it has.
Ron, you should be good to go with Notepad!
Ron Whitaker
on May 11, 2015 at 3:04:57 pm
I tried installing Notepad, but it doesn't appear anywhere. Just to confirm, where do I go after installing it to start it in Vegas 13?
Thanks.
Wayne Waag
on May 11, 2015 at 3:22:05 pm
It should be under View, Extensions.
wwaag
Jorma Nippala
on May 11, 2015 at 3:23:31 pm
[Jorma Nippala] "See View > Extensions."
As Wayne confirmed.
Steve Rhoden
on May 11, 2015 at 3:36:47 pm
Have you looked in the customized toolbar window?
Ron Whitaker
on May 11, 2015 at 5:18:34 pm
I checked under View > Extensions and it wasn't there. I also checked under Scripting. I'll have to re-install it and see. Is 1.2.0 the latest?
Graham Bernard
on May 11, 2015 at 5:42:06 pm
Ron, just installed VASST Notepad and working here in VP13:
G
Ron Whitaker
on May 11, 2015 at 6:06:09 pm
I'll uninstall, then reinstall.
Is the link I used in my original post the best place to download the Notepad installation file?
Jorma Nippala
on May 11, 2015 at 6:12:11 pm
Ron,
I used the download file (v. 1.2.0) in that link with success today.
If this does not work for you, you may need to wait for JohnR to chime in.
Ron Whitaker
on May 11, 2015 at 6:50:26 pm
I'm at work now, but later I'll try to reinstall.
Aaron Star
on May 11, 2015 at 6:38:41 pm
When I do this, I just use Markers(M) and Regions(R) inside the trimmer. You can add notes to the regions/markers, then add more in comments, and view all in "edit details" window. You can also cut and paste the edit details into excel for more notes.
Ron Whitaker
on May 11, 2015 at 6:50:52 pm
OK. Where are Comments located?
Aaron Star
on May 11, 2015 at 11:58:30 pm
Comments are a column under the project media window, that you can move the column and resize it.
Markers and Regions are shown under the edit details window, by selecting the Markers or Regions display filter.
Tags might be useful as well, especially if you use Sub-clips. Sub-clips are a great organizational tool when cameras were kept rolling for long takes. You can tag up your clips by camera, content, star rating, whatever you want. Then you can search or filter by tags. When you create a tag, a Tag bin is automatically created to contain that tag.
When you use the search function in the media window, your search is create as a short cut under Smart Bins.
Multiple monitors, even that old 10 year door stop monitor, can be a real help cause you can dedicate a monitor for media info and spread out.
Ron Whitaker
on May 12, 2015 at 3:29:10 am
I've uninstalled and re-installed. Notepad still doesn't appear within Vegas 13.
Where should the installer be installing it?
Russ Froze
on May 12, 2015 at 8:25:33 am
Yes notepad shows up in my version of Vegas Pro 13. I find it under view, extensions.
Russ Froze
Jorma Nippala
on May 12, 2015 at 11:51:35 am
Ron,
I find the Vasst extensions installed in C:\Users\username\AppData\Roaming\Sony\VegasPro\Application Extensions.
While waiting for JR to come along, you might read this thread and his posts there.
Ron Whitaker
on May 12, 2015 at 3:17:38 pm
When I install, it's wanting to put the files in c:\program files(x86)\vasst\freeware.
Is that correct? Does it matter?
Jorma Nippala
on May 12, 2015 at 3:43:18 pm
I do have Notepad.dll there as well along with uninst-Notepad.exe.
Ron Whitaker
on May 12, 2015 at 4:33:52 pm
I'll just try uninstalling and reinstalling later today. I don't know why it's not working.
Ron Whitaker
on May 13, 2015 at 1:41:46 am
OK. I FINALLY go it!
I reinstalled, but could not get it in either Edit > Extensions or Tools > Extensions...BUT I noticed that it was in the Customize Menu, so I placed there, which I like better anyway!
Thanks for all your help.
Steve Rhoden
on May 13, 2015 at 9:23:06 pm
Oh man!!! Finally Ron, lol.
Have no idea why notepad wants to give you so much hassle, lol.
Anyway, glad you now seeing it.
