What codec should I use to render SonyVegas project to DavinceResolve?
COW Forums : VEGAS Pro
Heer Need
on May 10, 2015 at 3:28:03 pm
Hello everyone!
I have to get SonyVegas project to DavinciResolve for color correction. SonyVegas running on PC and Davinci running on Mac. I want to render as high quality video as possible and then use Davinci scene detection. What is the best format and codec for render? I need to best quality for color correction.
Thank you!
Heer
John Rofrano
Re: What codec should I use to render SonyVegas project to DavinceResolve?
on May 10, 2015 at 7:26:35 pm
[Heer Need] "I want to render as high quality video as possible and then use Davinci scene detection. What is the best format and codec for render? I need to best quality for color correction."
I would use Avid DNxHD for all video transfers between PC and Mac. I have a tutorial on my web site on how to create the Vegas Pro template for it:
Avid DNxHD Template for Vegas Pro
You'll also need to install the Avid DNxHD codec on the Mac. This should give you excellent results across the two systems.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Dave Osbun
on May 11, 2015 at 2:20:32 pm
I always take my files into Resolve first, do my corrections, then I export for editing.
I'm not sure if that's how others do their workflow, but it's easier for me if I do it this way.
Dave
Timothée Ferreol
on May 27, 2015 at 8:58:33 am
Dave, you color correct all your footage before exporting them to SVP ? Wow how long does it take you ? Plus won't you be color correcting footage you will remove later in editing ?
___________________________________________
If you want to check out my work =) : https://vimeo.com/timof
