Best fps for video of just one image with backing music
COW Forums : VEGAS Pro
dwayne trinidad
on May 4, 2015 at 10:11:16 pm
I'm trying to make a really simple but long video which is just one image with a couple of hours worth of music.
The file size is 26gb when it is rendered!!!
I'm guessing it is so large because it's rendering at 29fps. If it's only a single still image, then I would have thought that I don't need 29fps (that's for motion right?).
Can't I set it to 1 fps or if not, what would be the best setting to use?
Thanks.
Mike Kujbida
Re: Best fps for video of just one image with backing music
on May 5, 2015 at 12:20:51 am
What format are you rendering to? How do plan to play it?
dwayne trinidad
on May 5, 2015 at 7:05:24 am
It was mp4.
I want to put it on YouTube.
Angelo Mike
on May 5, 2015 at 2:30:31 am
The bit rate affects file size, not fps. For a still picture I'm not sure it makes much difference. But bring the bit rate way down, especially since for a video that's just a still image you won't need it high.
dwayne trinidad
on May 5, 2015 at 7:04:18 am
How do I lower the bitrate?
Angelo Mike
on May 5, 2015 at 2:06:50 pm
You change that in your render settings. Go down to "Customize Template" when you open it and you can probably lower it significantly. Maybe try 3 or 4 mbps instead of wherever it is now.
dwayne trinidad
on May 5, 2015 at 9:39:55 pm
Thanks Ill try it
Mike Kujbida
on May 5, 2015 at 2:10:47 pm
There are several different templates for mp4.
If I'm rendering for YouTube, I use the free Video4YouTube extension from the good folks at Vegasaur.
http://vegasaur.com/download
If size is a concern, use the Vegas Pro to HandBrake method as discussed in this thread on the Sony Vegas forum.
One-click frameserving from Vegas to Handbrake
Using this method I was able to get a 2 hr. video file down from 10 GB. to under 5GB. so I know it works great!!
