Adding a tiff graphic with a transparent BG
COW Forums : VEGAS Pro
Rob Lindsay
on Apr 29, 2015 at 7:06:03 pm
The background turns black on the timeline. I want the BG to be transparent as it is in Photoshop, so the letters float over the scene in the lower track.
Is there a fix for this?
Many thanks!
Graham Bernard
Re: Adding a tiff graphic with a transparent BG
on Apr 29, 2015 at 7:10:13 pm
I thought only PNGs could provide a ALPHA channel in Vegas. Ok, right click on the TIFF and select PREMULTIPLIED.
TIFF eh? Didn't know.
Grazie
Russ Froze
on Apr 30, 2015 at 12:37:03 am
I don't recall exactly but the trick is to export the alpha from photoshop. It will need to be a 32 bit version of the tiff.
Russ Froze
Graham Bernard
on Apr 30, 2015 at 6:22:22 am
Russ, I researched the PS options. It's a bit fraught. I'd suggest, if Rob is still reading this, would be to go back and either try and save as PNG with ALPHA in place, OR if layered, try a straight layered Photoshop PS file. This can be imported as a layered option in separate Vegas Tracks!
Grazie
Russ Froze
on Apr 30, 2015 at 6:35:08 am
Yes Grazzie you are quite correct png would be a better choice unless you need the extra info embedded in the tiff.
Russ Froze
Graham Bernard
on Apr 30, 2015 at 6:48:22 am
[Russ Froze] " . . . unless you need the extra info embedded in the tiff."
Would that be resolution "info" or the layers "info"? If it was layers then the PS layered ting would be worth exploring.
Interesting,
Grazie
Russ Froze
on Apr 30, 2015 at 6:51:13 am
No, as I remember the settings are adjusted in the export window.
Russ Froze
