How remove sliver of pillarboxing?
COW Forums : VEGAS Pro
Peyton Todd
on Apr 25, 2015 at 3:06:03 pm
In an earlier post I was faced with a sliver of letterboxing, which John Rofrano solved by pointing out that I should set my properties to match the 720 x 480 source, but since I was using square pixels instead of .9091, I should multiply the 720 width by .9091 to get 655 for the 4x3 output I desired.
Unfortunately, this time I have a pillarboxed result, and I have been unable to find settings that remove this problem. When I set the properties to match those of the source - which are the same as before:"24.4 Mbps, 720 x 480 (4:3) at 29.970 fps DV (Sony) (NTSC) (DVCPRO)" (per MediaInfo), this doesn't change the preview window, nor the output either, across several different parameters I (more or less randomly) chose.
If this tells you anything: When I experimented with different widths in the properties window, I was able to change the sliver of pillarboxing to a sliver of letterboxing by choosing a width of 692, but with the width set at 693 I'm back to pillarboxing (in the preview window).
Incidentally, it seems odd that I get the opposite problem with this source than with the one in my earlier post since it was shot with the same ancient Sony portable video camera long ago (ca. 1970), when only 4x3 ratio black and white video was available. All this set of videos was converted to AVI in 2002. And all worked fine in earlier versions of Vegas.
I should mention that I have no particular reason for choosing either square or .9091 pixels. The built-in NTSC DV (720x480, 29.970 fps) choice in Vegas come with .9091, which is fine with me as long as I get rid of the pillarboxing/letterboxing problem.
Thanks for your help.
john bolton
Re: How remove sliver of pillarboxing?
on Apr 26, 2015 at 7:31:46 am
What happens if you Open Event Pan/Crop, then right mouse on it and select Match Output Aspect?
Peyton Todd
on Apr 27, 2015 at 12:33:12 am
Thanks, going to pan/crop and choosing Match Source Aspect worked perfectly!
John Rofrano
on Apr 26, 2015 at 12:13:00 pm
I'm not following what's different this time. If you start new project and use the match media settings to match the project to the media do you still see letter boxing? (you should not). Is it because you have different kinds of media and some match but others don't? If you are working with DV you should be able to just use the standard DV setting in Vegas Pro and everything should match. Why is this DVCPRO media different?
Try using Pan/Crop as John Bolton suggested but you shouldn't have to do this if your project is set correctly and your media really is DV.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Peyton Todd
on Apr 27, 2015 at 12:53:15 am
I do get good results with the same AVI file if I simply open it in a brand new VEG project. That solution is far from ideal, though, since I have a lot of editing work invested in the current VEG file, which was always working in earlier versions of VEGAS.
Fortunately, John Bolton's solution worked perfectly in the current Vegas file, even though simply choosing the correct parameters from the list box offered by Vegas in the Properties dialog did not. I wish I could tell you why.The choice offered in the Properties dialog said "NTSC DV (720x480, 29.970 fps)", and picking it sets the pixel size to .9091, which is exactly what MediaInfo tells me (although MediaInfo does not mention pixel size). Strangely, choosing Match Source Aspect does not change what appears in the Properties dialog. As long as I have chosen Match Source Aspect beforehand, I get perfect 4x3 results even with properties set to HDV 1080-60i (1440x1080, 29.970 fps).
With my problem solved, I can now proceed with my work. But in case you - as a video guru - have an interest in trying to get to the bottom of the problem, let me know, and I'll place the AVI and VEG files on Dropbox for you to have a look at.
Thanks again for your help.
John Rofrano
on Apr 27, 2015 at 11:02:07 am
[Peyton Todd] "But in case you - as a video guru - have an interest in trying to get to the bottom of the problem, let me know, and I'll place the AVI and VEG files on Dropbox for you to have a look at."
I'd be happy to take a look at it if you'd like. I also curious as to what might be going on.
~jr
Peyton Todd
on Apr 27, 2015 at 12:52:06 pm
Okay, here's the link to the two files, VEG and AVI. Enjoy!
https://www.dropbox.com/sh/v3yefe8069i9f44/AAAO4dgFllhvUDRZVrZViPGca?dl=0
john bolton
on Apr 28, 2015 at 7:40:32 am
Are the files still there or did you remove them? I am also curious but Dropbox seems empty?
john bolton
on Apr 29, 2015 at 7:48:16 am
Yes it did work. Very strange... I will have a play
John Rofrano
on Apr 29, 2015 at 11:28:42 am
Got them... i'll have a look and get back to you.
~jr
John Rofrano
on Apr 30, 2015 at 11:16:14 am
I looked at your footage and the black bars are actually part of your source video. There is nothing you can do about that except crop them out.
BTW, the project you uploaded was using an incredibly tiny 320x240 resolution that had a different aspect then your source video so that causes problems as well. You should keep your project at the same resolution as your source for best quality.
~jr
Peyton Todd
on Apr 30, 2015 at 2:17:39 pm
I'm relieved that it was so easy to solve since that means there are not future gotchas (at least of this particular type) awaiting me as I continue to work through my data. Not only is the solution to this one available (thanks to you), but it's easy to see that this situation must have arisen when I went ahead and saved a letterboxed video without fixing it.
As to the poor resolution, that could have either of two likely causes: (1) in my ignorance, I was experimenting with parameters, and had got more or less acceptable results with that setting; (2) at one point, I had decided to go with smaller videos to reduce the file size of the resulting PDFs, an approach I discontinued when a reviewer of a paper I wrote complained that he couldn't see the signs clearly enough.
In case you're curious, the project is about a child of normal hearing but deaf parents, whose early speech followed the grammar of his native sign language. Now that he's an adult, I have videos of him expressing in sign language the same sentences he spoke as a child.
Thanks again,
Peyton
