Disc check corrupts project files?
COW Forums : VEGAS Pro
Paul Smith
on Apr 10, 2015 at 9:44:07 am
I am using Windows 7 and Sony Vegas Pro 12
Recently I started making a project in Sony Vegas, when i restarted my computer a disc consistency check came up. I thought it was nothing so I let it check but when I came back to my project it had been corrupted.
I got my project back from an auto-save but now the disc check comes up every time I start my computer and I have to skip it to stop it from corrupting the project file again.
Is there anything I can do?
Dave Osbun
Re: Disc check corrupts project files?
on Apr 10, 2015 at 1:17:08 pm
Obviously that disk should not be used again. If it is NOT your system drive (where the OS is installed), you can download any number of data recovery tools to scan that drive, 'pluck' off what you need and place them on the new drive. Hopefully the bad sector is not exactly where your project file is.
Dave
Paul Smith
on Apr 11, 2015 at 10:22:27 am
Is there anything I can do if it is my system drive?
Bob Peterson
on Apr 11, 2015 at 2:52:50 pm
Try backing it up before you replace it. Also, some drives come with software which copies the current system drive before the new drive gets installed. This was the case when I recently upgraded the SSD that is my system drive.
