error; render exceeds max file size
COW Forums : VEGAS Pro
Kevin McCarthy
on Apr 7, 2015 at 5:00:21 am
I am trying to render a 3hr 7 min audio file to a wav file to process in my external audio editor. I get a message that render exceeds max file size.
I have never seen this one before and I can't find anywhere to adjust limitations
Any ideas?
Kevin McCarthy
Re: error; render exceeds max file size
on Apr 7, 2015 at 5:02:41 am
update the error says it exceeds the max limit for file type. I am trying to render to a 48k WAV file
Aaron Star
on Apr 8, 2015 at 6:57:52 pm
Try outputting to Wav64, or segmenting the output, or use a compressor like AC3, MP4/MP3. File size limitation was one of the main reasons for WAV64.
Russ Froze
on Apr 7, 2015 at 6:23:12 am
I am curious to know, from where did the file originate, how was it created?
Russ Froze
Kevin McCarthy
on Apr 7, 2015 at 1:44:28 pm
It is a file from an imported DVD and I usually have no problem qith this type of render from this source
Nigel O'Neill
on Apr 8, 2015 at 12:26:52 pm
[Kevin McCarthy] "render exceeds max file size"
Just out of curiosity, are your hard drives formatted to fat, fat32 or ntfs?
My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 12 (x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
Kevin McCarthy
on Apr 8, 2015 at 1:37:50 pm
Yes drives are fine and nothing has changed except for the fact that I had just installed the latest update
Would that have re-set the time line length and if so how do I extend the time line length? I can't find that setting
I don't think this is the problem though as both audio and video are already on the time line and work well
Kevin McCarthy
on Apr 8, 2015 at 6:07:49 pm
Still no solution. I tried to use the "open in external audio program" and it too says render exceed maximum file size for this format
Russ Froze
on Apr 10, 2015 at 5:47:32 am
[Kevin McCarthy] "Still no solution. I tried to use the "open in external audio program" and it too says render exceed maximum file size for this format"
Well the only thing I can suggest is to do an analog transfer. Record it to the workstation or an external recorder.
Russ froze
